Tremors When Left Right
08.05.2020 16:13 # 1
EmRe26
New malfunctions occur in the car: D When I do it right, I say from the right wheel, there is a tremendous flickering hum from the front right. For example, when U is spinning or where I am. When I left right and start to move forward, I do not understand that sometimes it comes intermittently. Why do you think ??
08.05.2020 16:13 # 2
I know it's normal because the steering pump has trouble
08.05.2020 16:13 # 3
EmRe26
No, it was not coming in. When we made a full left, we did not make a slight sound.
08.05.2020 16:13 # 4
tlp
The same problem happened with me, brother and still there. The steering wheel is turned to the left is 90 km and is trembling at the top, as if it were like a cat's eye, or a wobble. They went to the service, they paid 1000 TL, then went to the bi bi peugeot service and gave 3 pieces for us to take. The price of these is 100 TL :) 100 patterns in craftsmanship 200 TL ....
08.05.2020 16:13 # 5
Engin Tepe
Similar malfunctions were found in our Transporter. The shock absorber ball has changed in the pit on the right turn.
08.05.2020 16:13 # 6
mimitt
It should not be done right or left in turns, as it is known that the steering pump has difficulty, if this situation is not paid attention, the pump may have malfunctioned, the shock absorber ball throws as clicks and this is also felt from the steering wheel.
08.05.2020 16:13 # 7
There are also turns in me but only after doing the first workout in the morning. is it in the steering pump
08.05.2020 16:13 # 8
ByHack
Yes, not breaking the dissection completely is very important for the life of your steering pump. Especially in semi and full electric servo drills. I think the breakdown you said will be related to the front tool. Already a friend named "tlp" had a similar problem and it is understood from what he said. Show the situation to a competent master as soon as possible because the problems with the walking team do not neglect ...
08.05.2020 16:13 # 9
mimitt
Do not forget to check hydraulic fluids, friends.
08.05.2020 16:13 # 10
bayelektronik
If you have already done anything in your steering system, like pulling hydraulics and adding a new one, sometimes it makes air between the hydraulic fluid. ...
