Tremors on first run
11.01.2021 00:47 # 1
muratgunay48
Guys, I have a 2008 Peugeot 206. When the engine is cold, the engine shudders at first start. It passes after 5 seconds. This could be the cause.
11.01.2021 11:13 # 2
Hello, it can be engine mounts. Coil spigot. It could be fuel. In short, there are a few reasons, sir. at once clean the throttle.
11.01.2021 14:22 # 3
muratgunay48
Thank you for your answer. Coil is new. If there was a wedge, wouldn't it do it all the time? Can I run it on gas and try it?
11.01.2021 17:28 # 4
KILIC
During the day, does it always do this for the first time or when it is stopped for a long time, it works shaky.
11.01.2021 17:37 # 5
muratgunay48
No, only when it's cold. I just changed the spark plugs. We'll see it at night.
13.01.2021 14:57 # 6
KILIC
If the engine is cold but not repeated during the day, it is likely to be a gas pump. If the pump cannot make enough pressure, if there is less gasoline coming to the engine, the vibrating operation may return to normal after a while.
13.01.2021 17:35 # 7
muratgunay48
Sir, my second answer to this article. The wedge is in good condition. We changed the spark plugs and it was fixed immediately. Thank you very much. Best regards. I wish you a healthy day.
13.01.2021 17:36 # 8
muratgunay48
Thank you. Yesterday, based on the advice of my Soner teacher, I changed the spark plugs. Fixed. Thank you very much. I wish you a healthy day.
14.01.2021 17:22 # 9
x571
[QUOTE = KILIÇ] does it only for the first start in the morning during the day. If the engine is cold but does not repeat during the day, it is likely to be a gas pump. If the pump cannot make enough pressure, if there is less gasoline coming to the engine, the vibrating operation may return to normal after a while. What kind of path should I follow? Is the pump completely changing? is it repairing? x5712021-01-14 17:22:39
25.01.2021 21:05 # 10
djserp
If Gasoline is MAS / Diesel If it is Clean MAP Sensor problem It will be corrected, Also Service the Crank Sensors. It Is Oxidising It gets better in the mornings.
