tremor in the steering wheel
08.05.2020 19:10 # 1
selahattin
hi dear friends! The problem is that when the vehicle is in D mode, the steering wheel vibrates when the brake is applied. This tremor and sound freeze the steering wheel right and left. could the problem be from the steering wheel or a brake related situation?
08.05.2020 19:10 # 2
Zagorka
The problem is probably related to discs
08.05.2020 19:10 # 3
selahattin
So can you open up a little more?
08.05.2020 19:10 # 4
Zagorka
That is, the Disks may be worn or bent . A Tornacer Does Your Job. Or You Can Change Discs.
08.05.2020 19:10 # 5
selahattin
So today I showed the mechanic. the master looked right said that the axle was torn, said it might be from him.
08.05.2020 19:10 # 6
berk2309
does not vibrate from the bellows discs, if your front discs have expired, it will shake when you brake, even when you go with 120 140, the brake will play more right and left.
08.05.2020 19:10 # 7
Zagorka
[QUOTE = berk2309] discs do not shake from the bellows that if your front discs have expired, they will vibrate when braking, even when you go with 120 140, the brake will play more right and left on the steering wheel [/ QUOTE]
I agree exactly, but don't try it when you go with 140: D: D Bodoslama Dive into Bere, God bless ..
08.05.2020 19:10 # 8
Sercan Mungan
I am also trembling at a speed of 90 km, and when it passes over 90 and decreases to a minimum of 100 110, why could this be the reason?
08.05.2020 19:10 # 9
Zagorka
[QUOTE = 06MUNGAN47] I too do tremendous speed at 90 km speed, pass 90 and fall to a minimum of 100 110, why could this be due to balance? [/ QUOTE]
Can Be Welded From Rot
08.05.2020 19:10 # 10
Sercan Mungan
New changed on the front team Smile
08.05.2020 19:10 # 11
riderzist
[QUOTE = 06MUNGAN47] Just changed on the front team Smile [/ QUOTE]
You got the ball joint balance when you change the front team? :)
08.05.2020 19:10 # 12
riderzist
[QUOTE = selahattin] so today I showed it to the mechanic. the master looked right said that the axle was torn, said it might be from him. [/ QUOTE]
axle seal is very important. Do not even use it, do not feed it to the end of the axle, dust soil, rain sludge .. :)
08.05.2020 19:10 # 13
riderzist
[QUOTE = selahattin] hi dear friends! The problem is that when the vehicle is in D mode, the steering wheel vibrates when the brake is applied. This tremor and sound freeze the steering wheel right and left. could the problem be from the steering wheel or a brake related situation? [/ QUOTE]
Check your discs, is there any thinning scratches etc.? Have your linings checked. rotbalansçi can give clear information.
08.05.2020 19:10 # 14
Canberk35
As friends say: With brake, especially when light braking at high speeds, if there is tremor, discs are most likely distorted. It needs to be turned or changed. If the vehicle vibrates without braking, there is a problem with the rods. Needs adjustment or change.
If the felts are torn, do not neglect it. Refresh. It's pretty cheap anyway.
Canberk35 2015-03-17 03:25:47
08.05.2020 19:10 # 15
selahattin
In other words, when I stop at the d position, it happens when I press the brake. There is no problem in the NR and p positions. Turning the steering wheel to the left, it increases trembling and this tremor occurs without moving.
08.05.2020 19:10 # 16
vpro
D is the car going without stepping on the gas? If the clutches are doing where it stops without any trouble, can it be from gear?
08.05.2020 19:10 # 17
Canberk35
[QUOTE = selahattin] So when I stop at the d position, it happens when I press the brake. There is no problem in the NR and p positions. Turning the steering wheel to the left, it increases trembling and this tremor occurs without moving. [/ QUOTE]
- The clutch may be peeling off as the vehicle tends to travel continuously in the D position. There may be a problem with gears or lubrication.
- Since the vehicle is trying to grip continuously in D position, the speed may be too low and the vehicle may be starting to shake due to the low speed.
- If there is LPG, there may be an irregularity in the gas settings.
Check the engine speed in the D and N positions, that is, vibrate and not vibrate by looking at the tachometer. If it falls too low at position D, this is probably the reason. If the car is still at a level that can be considered normal, I recommend that you have the gear checked as soon as possible. Automatic gear does not joke. I think that if the brakes do not tighten, the car will go even if it is miles. It's a very small possibility. Brakes cannot be finished that degree. I hope it's a minor problem. Thumbs Up
Canberk35 2015-03-17 13:54:28
08.05.2020 19:10 # 18
selahattin
In D position, the vehicle moves forward or backward without pressing the gas. Can't be related to the steering pump, right?
08.05.2020 19:10 # 19
selahattin
Should I change the gearbox oil?
08.05.2020 19:10 # 20
Canberk35
[QUOTE = selahattin] I wonder if I need to change the gearbox oil [/ QUOTE]
Especially in automatic transmission vehicles, it is recommended to change the gearbox oil at maximum 50.000 km. Changing the oil can solve your problem somewhat, but I don't think this shake is entirely from transmission oil. Still, I hope you will get rid of small costs. Thumbs Up
Page : / 2
