tremor in the steering wheel
08.05.2020 15:33 # 1
goktug
friends after 120, the steering wheel trembles too much. Especially if you have reached 150, it will almost slip out of my hand. There is rod balance adjustment. the tires are neither too old nor too new. why do you think the problem is?
08.05.2020 15:33 # 2
Kemanyak
There may be rim curvature, and I would recommend that you take a closer look at the balance setting.
08.05.2020 15:33 # 3
ErcaNKarsI
the problem is on the front team :) go to a trusted master tell me your complaint immediately.
08.05.2020 15:33 # 4
statistican
I recommend you to change the Z rods in pairs on the front set are not too expensive ... it largely solves the tremor problem, of course, may be in balance and rim curvature ...
08.05.2020 15:33 # 5
As the friends say, the front team needs to be overhauled. There is nothing to be afraid of.
08.05.2020 15:33 # 6
dinoco
friends wrote the possibilities ..
but; tires may have a base skip / wire break in one or more of the tires.
08.05.2020 15:33 # 7
If there is a curvature of the rim, it does not easily balance, so replace the rear tire with the front tire.
08.05.2020 15:33 # 8
trtolgi
balancing required. a good master
08.05.2020 15:33 # 9
goktug
thanks guys for the answers. So first let me look at the balance setting. As you said, let me change the rods, taking the opinion of the top, of course ...
08.05.2020 15:33 # 10
We are waiting for the result Göktuğ ... I hope you save with balance, brother .. easy to come ..
08.05.2020 15:33 # 11
goktug
Thank you, hopefully ..
08.05.2020 15:33 # 12
metin
[QUOTE = Dinoco]
but; tires may have a base skip / wire break in one or more of the tires. [/ QUOTE]
yes, I was going to say it too.
08.05.2020 15:33 # 13
Ego_Ist
I had the same problem after 90, though it was not very severe, there was a tremor, I looked at the front team, rods heads etc .. Then I went to rot-balance, there were curves in 3 rims, they were corrected and the adjustment was made, I am satisfied now there is no problem
08.05.2020 15:33 # 14
goktug
it can also be from rims. I'm going straight to the creek hill.
08.05.2020 15:33 # 15
mdincer34
I opened the same problem and I changed the faults part to my vehicle 307 front tool zero front tires zero rot balance new two times, the last resort was changed my brake discs. If the vehicle goes with 120, there is no other solution other than changing brake discs and pads like me. I just changed it, I did not have a chance to try it.
08.05.2020 15:33 # 16
goktug
I would be glad if you share the result ...
08.05.2020 15:33 # 17
ali oncu
I recommend you not to disrupt this situation.
