Tremor at the steering wheel between 170-200 km / h
08.05.2020 19:21 # 1
yasin26
The vehicle has a slight flickering in the steering wheel at 170-200 km / h. Tires zero michelin
08.05.2020 19:21 # 2
smhcesur
As soon as I do not rot, my teacher balances the tremor, I think it will be solved if you adjust the wheels on a good barrier. I had the same problem.
08.05.2020 19:21 # 3
oguzhan29
Balance well in 4 tires
08.05.2020 19:21 # 4
10URAKAR
don't speed too fast friends LOL
08.05.2020 19:21 # 5
DarkSilver
Yes, they usually balance the tires to the tires. It is hard to find a tire that adjusts to the shaft.
08.05.2020 19:21 # 6
ahmet_bjk
the problem may also be on the road if it doesn't do it every time
I have the same problem, but sometimes it starts to vibrate after 130, sometimes it does not even vibrate at 170.
08.05.2020 19:21 # 7
yasin26
Thank you all, the balance was adjusted again, the lead was renewed, the problem was solved
08.05.2020 19:21 # 8
samet206
We are talking about a 5-door vehicle. When the 170-200 KM speed reaches, 206 is already completely shaking itself, it does not take a lot of slight vibration in the steering wheel.
08.05.2020 19:21 # 9
Viserion
I see people talking about 170-200. My widow does not exceed 140: D
08.05.2020 19:21 # 10
fluoxytil
[QUOTE = yasin26] The vehicle has a slight shaking of the steering wheel at 170-200 km / h. Tires zero michelin [/ QUOTE], just like friends say, balance your problem from balance, 99% problem is solved, especially if the tires are new, even if the balance is made, after a while I sit, I need to balance again, I had the same problem, I had a balance, even one of the rims had a press. I had the problem solved, no shaking, no more rims if you don't have the most rim, you can handle it for 40 -50 TL.
08.05.2020 19:21 # 11
yasin26
Evwt balancing is really annoying. Before I get 206, after 100, it is very safe to say that it is entrusted to me but after all, my car has destroyed all my predictions, even if it is 160 km speed, it will take a long time without shaking, I think it is a problem. According to this, it is an enjoyable vehicle that holds a very nice road.
08.05.2020 19:21 # 12
ziya alp
We saw 170 LPG and 190 gas, we saw 206 1.4
08.05.2020 19:21 # 13
Turgutreis06
I saw 190 on the 180 slightly inclined ramp on the straight road ....
206 + Plus 1.4 HDİ (Urban Move)
