Tremor at high 206
08.05.2020 17:18 # 1
ufuk91
Friends, a problem that I have ignored for a long time has grown more and more and now I am disturbed. The gearshift knob is shaking a lot, especially at 4th gear at 3,000-3,500 rpm. He does it in other gears as well as 3 in 5, but not as evident and severe as in 4.
What can cause this problem, how much will I have in case of a problem?
08.05.2020 17:18 # 2
Barut
I had the same problem last year, I changed the left axle, it improved, if there is no problem with the axles, it looks at the engine chock, but it usually does from the axle.
08.05.2020 17:18 # 3
ufuk91
[QUOTE = 206xs] I had the same problem last year, I changed the left axle, it improved, if there was no problem with the axles, it would look at the engine chock, but it usually does it from the axle. [/ QUOTE]
How much did it cost you, teacher? There might be a problem with the axles, I can't say it's solid
08.05.2020 17:18 # 4
Barut
[QUOTE = ufuk91] [QUOTE = 206xs] I had the same problem last year, I changed the left axle, it was okay if the axles are ok, it looks at the engine chock, but it usually does it from the axle. [/ QUOTE]
how much it cost you. teacher? There may be a problem with the axles, I cannot say that [/ QUOTE] I bought a left axle for 200 TL and gave workmanship for 50 TL. I bought the axle from the falcon pejo and got it installed at the boshcar service.
08.05.2020 17:18 # 5
ufuk91
[QUOTE = 206xs] [QUOTE = ufuk91] [QUOTE = 206xs] I had the same problem last year, I changed the left axle, it was okay if the axles did not have problems, it also looks at the engine chock, but it usually does it from the axle. [/ QUOTE]
How much did it cost you, hodja? There may be a problem with the axles, I cannot say that [/ QUOTE] I bought a left axle for 200 TL and gave workmanship for 50 TL. I bought the axle from the falcon pejo, I got it installed in the boshcar service, hodja. = "0" alt = "Smile" title = "Smile" />
I have friends with another idea, let's evaluate every possibility, I can say to the masters to look at the city. I do not trust the masters anymore because of a few events that have happened to me, BCDEFG changes until the vehicle is recovered. I do not have a master to trust with my eyes closed, let me get preliminary information from you and go with that information, at least let this guy know and not get hit & nbsp; "Big ufuk91 2013-01-27 22:11:31
