Trembling in the vehicle
08.05.2020 21:05 # 1
Hakan55
Hello, I have the 2007 model 1.6 407 comfort. There is an uncomfortable flickering in my car, though not excessively. While the car is in motion, this tremor is less. I showed it to two masters, one for service. The master at the service said from the ear of the engine, the other master said that the problem was in the flywheel of the vehicle and that the clutch set should change along with the flywheel. I would be glad if you can share your knowledge and experience on this subject.
08.05.2020 21:05 # 2
possible problems teacher
1-engine and gearbox wedges
2-flywheel and thrust pad.
tremor usually occurs on departure or is it felt at idle.
08.05.2020 21:05 # 3
Hakan55
Thank you for your answer. Tremors often occur at idle.
08.05.2020 21:05 # 4
Ufuk_64
If it is from the ear of the motor, it can be understood immediately by looking at it, and the first starter vibrates too much when stopping the engine, shaking very close to stopping, understands this by looking at a good eye. Put a finger in the engine ear, there is excessive wear or rupture on one side.
08.05.2020 21:05 # 5
In idling, renew my teacher engine and shampoo.
08.05.2020 21:05 # 6
Hakan55
I just showed it to a different master, he said that the malfunction was caused by turbochargers and injectors. What do you think is rightfulness?
08.05.2020 21:05 # 7
mstfkrkmz61
The engine's bottom chock had lost its function. After changing to a new one this evening, the vehicle started to shake a lot at the first run and idling.
08.05.2020 21:05 # 8
emrermis
I know that the wedge will not get used to the process. It looks like engine and transmission ears, but that's the problem. Flickering is most likely due to engine ears if it stops when it travels or delivers light gas at idle
08.05.2020 21:05 # 9
Hakan55
First of all, thank you for your answer. The tremor has been going on for a while. Now I am having a hard time shifting gears. For this reason, we can say that the shaking is related to the flywheel and clutch set. A master I showed the vehicle said that the shake might be related to the injectors.
