Transmission Warning
08.05.2020 19:28 # 1
gokhanyalcinkaya
My car is 307 1.6 xt automatic. It has been 20 days since I bought the vehicle. I just finished the new maintenance, started to get in, but a warning came from the car yesterday. "Automatic Gear Faulted". Then, the gear and sport driving modes indicators started to flash on the gear display. I pulled to the right, stopped and restarted without any problems. This problem happened after 2 km in the first use in the morning, then after work in the evening, again about 2km. then it happened. I am waiting for your feedback if you have any information about this subject.
I also need a robust automaker on the Anatolian side of Istanbul. I want to change the gearbox oil.
08.05.2020 19:28 # 2
If you examine the following topic, it is likely that your problem will be solved.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=9612
08.05.2020 19:28 # 3
emreozer1988
The solenoid valve needs to be replaced, master. Another name is electro valve. these are the valves in the gearbox that serve as oil delivery. The car usually knocks in 2nd gear. this is because these valves are problematic
