transmission sound
08.05.2020 16:17 # 1
sedatdatse
hello friends
my car is 2001 xr 1.4 206
when going downhill, there is a noise when the clutch presses the clutch. intermittently
Do you have any fat or fat?
08.05.2020 16:17 # 2
berk2309
how can you describe the sound of the sound?
08.05.2020 16:17 # 3
You have a certain speed, around 40-50, and it comes when you press the clutch at that speed ... right?
08.05.2020 16:17 # 4
sedatdatse
the same thing happens after the brother accelerates 20 grandfather sounds
overtime I tried this too when there is no idle, after 20, it is set to 2nd gear.
08.05.2020 16:17 # 5
It can not be gears, nor can it be a secromeç. (No sound, I am talking about it as a `` garch '' style when I go from 1 to 2)
08.05.2020 16:17 # 6
sedatdatse
There is no problem when switching to 2nd gear. Is it time for oil? I bought the car birdre
I have this teacher 1. the gear is working like a reverse gear, but it's not as much as a reverse gear, so
& nbsp;
08.05.2020 16:17 # 7
Someone who faced a similar problem wrote in fordclubtr. He experienced this situation in 2000 model fiestas. he even talks about a slight jolt.
08.05.2020 16:17 # 8
[QUOTE = sedatdats A] 2. There is no problem when shifting into gear, is it time for oil? The gear is working like a reverse gear, but it's not as much as a reverse gear, so it is
& nbsp; / div>
for the repair to be opened for repair ....
mazda was a 1st gear synchromeist in lantisim. 500 pounds of labor was taken for the synchromesh gear. if it comes, the synchromesh gear is scrap.
08.05.2020 16:17 # 9
sedatdatse
scrape & nbsp; There is not much sound I said, and the vehicle's brake disc or something, I started to hear it thoroughly
08.05.2020 16:17 # 10
transmission oil does not deteriorate so easily. I don't think it is oil. Blinking "/>
maverick 2011-10-24 23:18:04
08.05.2020 16:17 # 11
sedatdatse
I wonder if there is a gap on the axle or whatever we do, we will look at the master sound
08.05.2020 16:17 # 12
sedatdatse
by the way, thanks for their interest
08.05.2020 16:17 # 13
There is clutch center ball, it was broken, I do not remember exactly how I will leave the pressure on the clutter.
08.05.2020 16:17 # 14
sedatdatse
Yes, there may be room, the bidet smell was starting to come off in serial departures.
08.05.2020 16:17 # 15
[QUOTE = sedatdatse] yes room may be the bidet smell started to come in serial departures center ball inside the press pad
thank you
what we call center ball socket post ball . "Blink"
transmission will go down . You will get a set. The workmanship is a bit heavy.
It will hold something around 450.
If you said it all over again, we would not have had a hard time smelling it came. = "Laugh" title = "Laugh" />
Your 90% clutch is out. as it went on the ball ......
08.05.2020 16:17 # 16
sedatdatse
workmanship is not important, just how much material do you think?
08.05.2020 16:17 # 17
Ask the falcon peugeot tomorrow, get a price.
are good trades.
an estimated 200-250 sets. print-pad-ball-ball ...
the best set Valeo I know. it is like cotton clutch. >
You also save 5% off gasoline.
08.05.2020 16:17 # 18
hasanxs
friends, I have a similar problem with this, while the vehicle is idle, there is a noise from the gearbox. I consulted a few masters, such as humming, and said that the ball was dispersed and made a permanent hoe.
