Transmission Revision
08.05.2020 21:08 # 1
Seyitali
Hello everyone. I just joined the forum
My name is Seyit ali.
My car 2002 model 2016 1.6 xt automatic
It's been about a month since I bought the vehicle. Reverse gear a few days ago
when i put it started knock
officially started throwing the car back. Yesterday too
that the car did not go into fourth gear and remained at 3
I've noticed. Today I went to Öztürk gearbox in Ankara.
Using the master gearbox requires complete overhaul like this
If I continue to make the transmission unusable
He said he would come. At least 3000 TL in price but
He said he could get up to 6000 TL.
Can I get information and suggestions from the inhabitants? So the price is too high
arrived in Ankara will be able to offer affordable reliable transmission master
I am waiting for your help from what happened.
08.05.2020 21:08 # 2
talip206
Öztürk transmission is good. There is also a master master that everybody praises. Write a Google veteran master automatic transmission results.
08.05.2020 21:08 # 3
Frt-Aydin
valla prompt opening inquiry
there is avni master in bostanci, ask the gearbox googla onda onada ask them personally they treated me so well they are not paracida.
If you need to give money immediately, go to 20 gearboxes and get an idea
Do not go to the service is already a disaster
08.05.2020 21:08 # 4
Seyitali
Thank you both, friends.
Let's see if I'll try to find scrappers and get out.
It would be less costly if I find something clean at least
08.05.2020 21:08 # 5
Frt-Aydin
Does the snow and sports lights stop flashing?
it is normal for the bidet to knock back when fitted.
For example, wait for a little while getting from the d position to the direct r.
knocking back in my car is not a problem
I think you should not go directly to revision.
look at the pressure values when the gear shifts into gear, the bidet looks at its pressures in gear while on the road.
I think it may be in the solenoid valve.
Nowadays things are going to be cut, folks are going to cut money.
research Research Research.
Connect to the computer for malfunctions.
