TRANSMISSION PROBLEM
08.05.2020 16:26 # 1
sosyete_60
FRIENDS YOU ALL HELLO MY 2001 1.6 16V Peugeot 206 THERE ALONE IN THE CAR PROBLEMS BEGAN the gearbox AUDIO NOT STARTED my foot CLUTCH A PRINTING I SOUND KESİLİYO DRAWS I SOUND CASE I puffin gearbox OIL CHANGE I GUINEA SAME BACK in GEAR & nbsp; VERY SOUND yapiyo USTA to said OLDUGUM the SHOW I GROUP SHAFT and ball BUT the USTA ALL WHAT IS DIFFERENT SOMETHING DIO? What do you think?
08.05.2020 16:26 # 2
peugeotefe
There is a problem in the socket pole ball or group shaft. The other possibility is the clutch ball.
08.05.2020 16:26 # 3
sosyete_60
So how do I say that I changed the pressure again, if it was in the clutch ball, the ball was installed and gave the same sound again.
08.05.2020 16:26 # 4
peugeotefe
If the ball is disassembled, it will be understood whether it is already broken or not.
08.05.2020 16:26 # 5
djchaos
[QUOTE = socyete_60] how about the clutch ball, let's say I changed the pressure again, the ball was installed and gave the same sound again, but when the gearbox was disassembled, the bad stuff was determined before the function came into operation,
deyaya brake pad disassembles when the gearbox goes down, there is a problem in the gears, if the vehicle is shaking at the start, if the clutch is grasping from the top, & nbsp; if there is a decrease in traction, the vehicle is shouting at the throttle, if the clutch pad is clutch pad, the gears are on the vehicle while the clutch pad is changing, check the gears and stop all the troubles. forward to the master you can get the necessary parts of our sponsor, falcon peugeotan, both relevant and affordable, plus the original piece
Şahin Peugeot
Original Spare Parts
0216 631 10 80
0216 631 18 12
0533 301 88 06
www.peugeotmarket.com
08.05.2020 16:26 # 6
toprak
war costs about 300 TL. but after that process, anarya sound will decrease 70%. going to the sound in the clutch. it happened to me last year but i can't remember exactly what has changed. felt has changed, bidet balls have changed, I think. Workmanship takes a lot since the gearbox is lowered
08.05.2020 16:26 # 7
sosyete_60
I hear my gratitude to the friends who helped me. I can't find that you are looking for a bit of trouble here because I'm slapped. .
08.05.2020 16:26 # 8
toprak
Oh, let me say something. this audio tool does not create an extra cost. The parts to be changed are obvious. Apart from that, it does not harm other parts. I rode with that voice for 1 year. it cost me the same cost a year later it turned out the same. shortage only annoying sound
08.05.2020 16:26 # 9
burak_08
friends I have a problem with the peugeot 206 automatic transmission. Does anyone know of a master who is dealing with these works in trabzon, or rather, but I could not find your name or something, I would be glad if there are friends who can help you ...
