Transmission problem
08.05.2020 14:06 # 1
& nbsp; Good evening everyone, first of all, I am a new member of the site and I would like to thank the founders of a really good site. My question will be my friends, my car is 2000 model 306 bva-xr (automatic) at 77,000 km & nbsp;, the sound of the car's transmission is especially 80 km. the speed increases, the speed decreases, the volume decreases, and occasionally the mileage drops to zero spontaneously (digital indicator is OK), I think if I do not have my vehicle service or my automatic transmission repairer. If I have friends who made it before, thank you if they share their information with me. How much does it cost me?
08.05.2020 14:06 # 2
peugeotefe
According to the view, you are in Ankara, if you send the gearbox to us, we will solve your work, but the speed that comes from the gearbox is not absorbed speed & nbsp; you are saying the clock is zero, it has no relation to the gearbox.
08.05.2020 14:06 # 3
hasimayaz
If I am not mistaken, BV4-XRs must have an AL4 transmission. There is one speed sensor in these, it is a bit of a problem when it gets hot. there is even a need for a sheet metal protection against the temperature.
& nbsp;
How did you know that the sound came from the gearbox? Are you sure?
08.05.2020 14:06 # 4
I took my car to the automatic gearbox repairer, took a test drive and said it was caused by the gearbox, already & nbsp; occasional & nbsp; snow and sports modes are blinking. When I stop and run it again it returns to normal. Actually, I think if my aim is in the service or if I can get out. I can't predict how much I can get out of the service, but this repairman I have taken outside has said that it can increase to 1000 TL, but I do not know what the warranty situation will be.
08.05.2020 14:06 # 5
Onur
there is a problem with the flashing of the lights because it is caused by the valve control unit in that gearbox. There are two cellophonoids, they need to change, I think 2 pieces of 500 ytl fln, I think 1000 pounds more. If you hit the ramp without getting warmer in cold weather, then it will make the car. hitting the steep ramp before the car gets warm
08.05.2020 14:06 # 6
Onur
For example, the solenoid kit price & nbsp; http://www.sahibinden.com/ index.php? a = 1014 & amp; b = 15,345,867
08.05.2020 14:06 # 7
ErolSen
this fault is similar to my fault (206 ov) sometimes when shifting gears & nbsp; A sound comes out of the box and the beep and warning lights are on, along with the snow and sports mode lights on the screen. I took it to the special service & nbsp; They had connected to the computer, a malfunction called pressure adjustment malfunction. They had said that a couple of parts mentioned above should be changed and they had a price of 500 TL including all inclusive. Maybe it will be useful for you to learn about the price. erolizma26 2009-12-14 23:38:03
08.05.2020 14:06 # 8
Onur
This problem does not matter chronic 206 306 in al4 gearboxes :( if the authorized service said 400 -500, thank you for informing very well
08.05.2020 14:06 # 9
ErolSen
You stated that the malfunction is chronic, I am not getting on my vehicle like this right now. So, will this malfunction repeat later on after having it done?
08.05.2020 14:06 # 10
Onur
I do not know if it is repeated or not. I have the same fault in me. I changed the solenoids did not make any more diode
