transmission overhaul
08.05.2020 15:06 # 1
buruker
Hello friends. I have a peugeot 307 for 8 months. There is a transmission problem in the car. There is no problem when it is cold, but when it gets hot, the tiptronic is disabled. I tried to take it to the master today, said the gearbox will be overhauled. He said that the car will explode at 120000.
08.05.2020 15:06 # 2
I made a revision, together with the solenoid valves, I found a total of 2000 lira. Thank goodness I have no question now. Everything went well. I made it in Ankara through Afyon Peugot Kutlu Brothers. You are in the source of this work ..
08.05.2020 15:06 # 3
buruker
Yes, there are good craftsmen here. I left the car somewhere that I thought was good, and the car will inform me tomorrow.
08.05.2020 15:06 # 4
metin
[QUOTE = buruker] hello guys. I have a peugeot 307 for 8 months. There is a transmission problem in the car. There is no problem when it is cold but the tiptronic is disabled when it gets hot. Gear shifts are diverting. as if somebody is coming from the back as if it was coming.I tried to take it to the master today, said the gearbox will be overhauled.It said that the vehicle will explode at least 120000de.At least 2000tly.I can get your comments.
where are you from istanbul
comments on this topic are available in the forum if you want to research them, you can handle it without going into revision?
They said it will be overhauled as well, but I solved the problem with oil change. There are comments of my friends and my friends on the site. Have a look at them.
these problems happen only because of the overheating. When he does not take precautions, he goes to revision.
08.05.2020 15:06 # 5
buruker
what's going on in pm.
Yes, it is getting hot because these problems are happening.
08.05.2020 15:06 # 6
metin
pm is a private message. I shared a link to some topics in the forum, where you can find the information you are looking for. these;
and
There are comments on the subject in the titles.
As a master, I recommend the avni master in the gardening industry. The man is competent.
respects.
08.05.2020 15:06 # 7
buruker
Yes, I left Avni to the master. They are collecting today. Let's see.
08.05.2020 15:06 # 8
metin
[QUOTE = buruker] yes I have left the master to the master anyway.
you have done well personally I trust the mastery of the man.
Also, we know because you have already written the problems in your car and what information have you changed in the face of these problems.
we also help friends who have the same problem.
08.05.2020 15:06 # 9
kizilhakan
I have al4 triptonic gearbox, your problem is very big. If you are in Istanbul, there is data peugeout ibrahim master. Ataturk auto industry site 51 street is an expert on these issues.
08.05.2020 15:06 # 10
buruker
I will buy the car tomorrow. I talked today, the pieces were collecting. I don't know what has changed. I will learn tomorrow. I will share the result in the forum.
08.05.2020 15:06 # 11
Haksen016
let's see, I hope the problem is solved.
08.05.2020 15:06 # 12
06ef
I have to stop and start the automatic gear fault Yazo car from time to time, but it did when the last car was colder ...
08.05.2020 15:06 # 13
buruker
the problems started with the error error in me.
08.05.2020 15:06 # 14
buruker
friends blew me up to 2750tl. i will write the details in a wider time. i hope it will not be a problem after that.
08.05.2020 15:06 # 15
metin
It is seen in everyone since there is such a chronic mistake in the gearboxes of the 307s. but I don't think it will cause any problems when you go overhaul and the man you have built is really a master.
However, one of the most important factors in its deterioration is the warming problem. As a result of this problem, it may be possible to break new parts. got to solve the warming problem.
08.05.2020 15:06 # 16
buruker
We gave 2750 TL but now it seems like no problem. I hope there will be no problem after that.
08.05.2020 15:06 # 17
metin
what was done, how much were you going to explain, we are waiting for news from you buruker
08.05.2020 15:06 # 18
buruker
Yes guys, sorry, I came back to the forum.It has been 10 days since the revision process has been made.I went to the city of Beylikdüzü. No problem. I listened to the gear d or p when I get a fine voice called ssss, I do not know is normal.
1set gasket 235tl
2pcs band 240tl
1pcs filter 35 tl
1pcs band screw 150 tl
1pcs bushing set 220 TL
1pcs pump cover 150 TL
turbine evolution 300 tl
240 TL for 2 pcs solenoid valves
1pc heat exchanger 225tl
1pcs heat exchanger bolt 25 TL
cleaning liquid 50 TL
7liter oil 140 tl
320 TL of labor
A total of 2750 TL. I am waiting for your comments. Regards ...
08.05.2020 15:06 # 19
Fairy tale well kept the number: ((I hope you use it for a long time without problems.
How did we mix the band screw in the list, but there is the price of 150 TL ...
08.05.2020 15:06 # 20
buruker
it was carrying a band that was not a screw for the band.
Page : / 2
