Transmission Oil Leakage
08.05.2020 20:41 # 1
hakani
Hi there, 307 XR Peugoutum has oil leakage from the gearbox seal. The master said it would cost 1500 lira here. Felt is only 80-100 lira, but because of opening the labor transmission, the price is very much.
08.05.2020 20:41 # 2
RP393
I will be as soon as I jumped, if I have a mistake, other friends should make up.
When changing the pressure pad, the gearbox comes down and completely disassembles. I think a felt doesn't hold that much. I wonder if there is a rent payment.
08.05.2020 20:41 # 3
hakan brother, do you have the opportunity to take a photo of the axle seal you called transmission gear?
08.05.2020 20:41 # 4
hakani
The master cleans the axle seal or the felt between the transmission. A few days later he looked again from the transmission. But the fee came to me too.
08.05.2020 20:41 # 5
monalos
The fee is really high, did you ask other masters?
08.05.2020 20:41 # 6
hakani
[QUOTE = sonerkyl] hakan brother, do you have the opportunity to take a photo of my axle seal, which you call the gearbox? [/ QUOTE]
08.05.2020 20:41 # 7
In my opinion, my master brother who said the price is too high, I would look at other masters. let's say, get the shaving, lowering and 250-300 TL, and the material is 150. holds a maximum of 600-700 TL. if there is no other problem.
08.05.2020 20:41 # 8
GokhaN
The transmission seal must change to a maximum of 500-600 with oil change or completion
08.05.2020 20:41 # 9
hakani
I found a good master, the transmission was found to be leaking right in the middle, but he said no need to open it for now. He said that even if we open it, it would cost 600 lira. Could this leakage be like silicone ???
08.05.2020 20:41 # 10
Silkon does not benefit, my teacher does not keep the leaking oil cold outside. Do not leave the shampoo oil incomplete then there will be no problem until you get it done.
