Transmission Oil Leakage
08.05.2020 19:35 # 1
stain1903
Good day guys, I have a 307 hdi 2004 model car. Two days ago the car's pressure-pad and flywheel and clutch fork replacement were made. When I woke up this morning, I saw that oil was coming under the car.
08.05.2020 19:35 # 2
If there is no excessive leakage, there will be no problem with dropping, but if the oil incontinence increases after the engine warms up, it may cause trouble. Use 10 km, stop and check and do not risk if there is a proliferation in the leak.
08.05.2020 19:35 # 3
stain1903
[QUOTE = sonerkyl] my teacher doesn't have a lot of leakage or drips all the time, but if the oil incontinence increases after the engine warms up, it can cause trouble. Use 10 km, stop and check and do not risk if there is a proliferation in the leak. [/ QUOTE]
Thank you for your interest. 50 km I came, there is no problem, I hope there will be no problem in return.
08.05.2020 19:35 # 4
You're welcome, the reason is the purpose of our form. Accident-free trips.
08.05.2020 19:35 # 5
stain1903
Distress felt. There has been a change from the bottom of the car, and I hope it will not happen.
08.05.2020 19:35 # 6
ose
[QUOTE = stain1903] Distress felt. There has been a change from the bottom of the car, and I hope it will not happen. [/ QUOTE] If you write the cost, how many pieces of workmanship will your friends know.
08.05.2020 19:35 # 7
yusufmercan
The pressure has changed the pads, so much has been done.
08.05.2020 19:35 # 8
vpro
I changed the felt to 5 liras, it was 50 TL in labor
08.05.2020 19:35 # 9
stain1903
i didn't give money
