transmission oil leak |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:41 | # 1 |
| 08.05.2020 16:41 | # 2 |
First of all, whether or not you can see exactly where the oil leakage can be. & nbsp;
| 08.05.2020 16:41 | # 3 |
I did not look at it in full detail, but as if the screws under the gearbox had missed the junction points from there.
| 08.05.2020 16:41 | # 4 |
If it has escaped from there, it was difficult because I made the transmission when I got it done, I made it from the abc peugeota & nbsp; I am in Cyprus, they changed, no oil leap, now they said they came, started again & nbsp; I searched for the warranty, when it comes in June, change it and add it as soon as the oil decreases. & nbsp; There is a hatch among the converter, great prospect, throwing away from it & nbsp;
| 08.05.2020 16:41 | # 5 |
Well, I have too many of you, I don't even know if he's throwing all the time. As if it was getting hot, I made it 800 km yesterday.
| 08.05.2020 16:41 | # 6 |
the tool will drop drop as long as the pressure builds up & nbsp; It does not cause any problems, but as the oil deficit increases, it seems that the hit starts and the hardness of the views hardens & nbsp; By jumping in the night, when the oil decreases more and more, the band set lights up the pads. In this case, you can reduce the transmission and get a complete revision. & nbsp; there is a certain level of putting oil on the press with certainty; neither few nor most perceive thoughts & nbsp;
| 08.05.2020 16:41 | # 7 |
Now it seems like there is not much trouble, only when the shrinking gear shrank below 20 cycles in the past, it would do now when it falls between 10-20, no problem other than that, I have been using it for 2 years, I did not change any oil anyway, I would change it this month. have you been satisfied
| 08.05.2020 16:41 | # 8 |
I am glad I did a complete revision, the acquaintances cost like something like 1700 lira but it did not change me, but all the times were all changed, the materials are not money, but the material is expensive, there is another point in the brake pedal. After the gear is gone, after a while, it gives signal errors and presses the brakes.
| 08.05.2020 16:41 | # 9 |
:) yeah they said that i changed it last week. I will ask you one more thing, you know that it is completely overhauled, you do not have such trouble, just change the oil is not enough, so this solenoid valve or something, do you need to change them?
| 08.05.2020 16:41 | # 10 |
connect it to the computer pressure in both the d and r and if the pressure is low you change it & nbsp; this already costs 700 lira & nbsp; 30 000 km of oil in your car.
| 08.05.2020 16:41 | # 11 |
Yes, last year, when the weather fell below -10 in the winter, it gave 2-3 times when it got warmer.
| 08.05.2020 16:41 | # 12 |
When you start to get this error too often, I recommend that you change the oil first, if there is no solution, the solenoid valve change is required. When I go to 2nd gear in my vehicle, I will ask for something & nbsp; Throw in gear, like drop off, and then throw in the 3rd gear & nbsp;
| 08.05.2020 16:41 | # 13 |
There is no cycle drop, but it seems like it is doing a transitional transition. I got this error a little under -10 but I hope it is time to change slowly, solenoid valve is good :)
| 08.05.2020 16:41 | # 14 |
I asked him if we were like this: D & nbsp; I asked the master on this & nbsp; Unloading the excess pressure in the torque converter, the propeller has been damaged, he said, because I don't have to worry about it. especially if you have an AL4 like & nbsp; very good research & nbsp;
| 08.05.2020 16:41 | # 15 |
No, God, keep it from the evil eye, I don't worry about my belief.
| 08.05.2020 16:41 | # 16 |
no no 2 plugs, no problem, it's okay for you to be comfortable, but if you think the oil leak will be obliged it will be painful & nbsp;
| 08.05.2020 16:41 | # 17 |
there is oil leakage, they do not dismantle it in the felt.
| 08.05.2020 16:42 | # 18 |
If the torque converter blows out of the lap, they will have to suffer but I do not think that the fear will change, I don't think it will just be as far as I know.
| 08.05.2020 16:42 | # 19 |
this is not something expensive, I guess :) I guess the brains of the abs were just Saturday, I changed it and gave it 600TL :)
| 08.05.2020 16:42 | # 20 |
When I hear the price of Vala, I will say lips and lips: D go to the original peugeot dealer: D 13 tl: D but is 80 lira: D & nbsp;
