Transmission oil color hk.
12.03.2023 02:08 # 1
arifbsrn
hello friends.
I'm thinking of changing 2000 model 1.4 206 automatic transmission oil and cooler.
I bought coolant, oil and engine antifreeze. I hope the weather gets better, I will change it.
but I was confused, this transmission oil is yellow (mobil atf 71141)
it should be red in some issues Since it is written as
I contacted the places where I bought it and they said that this is the appropriate oil to be used in this transmission according to the chassis number.
precious of you too. I would like to get your opinions.
thanks in advance for your answers.
13.03.2023 19:56 # 2
talip206
Sir, I've changed a lot of oil so far, I even changed the oil cooler myself and installed a thick type. It was always red.
14.03.2023 15:07 # 3
arifbsrn
Isn't the oil code atf 71141 sir, I'm not talking about a wrong oil.
15.03.2023 20:34 # 4
talip206
yes this oil
15.03.2023 20:55 # 5
arifbsrn
Well, what is your suggestion, should I use this oil?
The product looks like the original (box - label etc.) (a group pejo at the entrance to ostim)
15.03.2023 21:53 # 6
talip206
The color is red, but not that crimson. We can say that between yellow and red is close to red. It gets darker as it ages.
https://youtu.be/B0x8ZRY90Gg
You can see the color in this video. In the 9th Minute
16.03.2023 10:37 # 7
arifbsrn
Thank you very much for your interest. Let's see if the weather gets better :)
I'll add the developments to the forum if I can handle it safely Smile
