Transmission oil check
08.05.2020 15:53 # 1
307 1.4 hdi, if I have a chance to check the transmission oil, how can I get it?
08.05.2020 15:53 # 2
metin
engine oil is not as easy as brake oil. As far as I have read from your comments, I think you have your own master.
08.05.2020 15:53 # 3
I want to do it myself when the easiest way to look at the master is done. I do not have some things to the right master anyway :) Corluda also master I was in Istanbul until the winter.
08.05.2020 15:53 # 4
metin
you should deal with the shortage as soon as possible.
08.05.2020 15:53 # 5
Even if the master oil was completely drained, it would take 1 month without any trouble. Transmission oil would be different, stick to the parts, I hope I will handle it next month.
08.05.2020 15:53 # 6
[QUOTE = hcthct] even if the oil was completely drained, he said it would take 1 month without any problems.
What kind of transmission oil did it run out of it for a month ??? Göz Kırpma
It came to me like a lot of mubalaga Kahkaha
08.05.2020 15:53 # 7
Actually, if I had it checked for me sometime ...
08.05.2020 15:53 # 8
forewer_fb
friends, if I ask a question about my chance in terms of lack of subject crowd. It comes to 6000-7000 revolutions in 1st gear and immediately shifts into 2nd gear, each time gaaaaaarçççç. What do you think is related to? There is no such problem with other gear changes,
08.05.2020 15:53 # 9
[QUOTE = by_ersin] is actually okay if I have it checked for a while ... [/ QUOTE]
I completely changed it. It already takes 2l of oil. But I put the Esso brand is a bit expensive. 1 liter like 20 tl. I also cared for the gearboxes in one night and the nights were more comfortable.
08.05.2020 15:53 # 10
I also did not understand that he explained the 1-month incident, even in the reaction, he explained that it was a long and long one.
08.05.2020 15:53 # 11
[QUOTE = forewer_fb] friends if I ask a question about my chance in terms of lack of subject matter. It comes to 6000-7000 revolutions in 1st gear and immediately shifts into 2nd gear, each time gaaaaaarçççç. What do you think is related to? There is no such problem in other gear changes, [/ QUOTE] It is an important thing, I think it may be related to the oil, it may be a problem in the gear, for example, when the vehicle is walking slightly, it comes in the same sound.
08.05.2020 15:53 # 12
[QUOTE = hcthct] also did not understand that I explained the 1-month incident, even in the reaction, explained that it was a long and long. ]
I never go under such a risk. It is not logical to embrace the transmission for 3 kurus oil
08.05.2020 15:53 # 13
[QUOTE = CeCoLi] [QUOTE = by_ersin] is actually not bad if I have it checked for a while ... [/ QUOTE]
[/ QUOTE] How much did it cost you all the transactions?
08.05.2020 15:53 # 14
[QUOTE = CeCoLi] [QUOTE = hcthct] did not understand it, I explained the 1-month incident, even in the reaction, explained it was long and long. moon saying [/ QUOTE]
[/ QUOTE] I am not going to wait for 1 month, but I will go to the place that changed the pressure pad.
08.05.2020 15:53 # 15
[QUOTE = hcthct] [QUOTE = CeCoLi] [QUOTE = by_ersin] is actually not bad if I have it checked for a while ... [/ QUOTE]
[/ QUOTE] How much did it cost you all the transactions? [/ QUOTE]
I bought the oil for 17tl, 2 lt 34 tl. Replacement cost is free Göz Kırpma You may only need to replace the washer above the sump plug when changing the oil.
08.05.2020 15:53 # 16
forewer_fb
There is no screeching gear as a gearbox, I pull light from the gear.
08.05.2020 15:53 # 17
Faruk
When you come to that time, if you pass 2 fast, it will make that sound.
I had 1,5 diesel kangoes, it would speed up from 1 to two, and then make a fast garbage Göz Kırpma
I haven't tried it in 307, I couldn't get up to speed Sırıtma
Faruk 2011-07-26 19:26:00
