transmission oil change
08.05.2020 19:14 # 1
erdemumut
Hello
My car is currently 142000, the gearbox oil has not changed before 2. There is a sound like rubbing noise in the second gear.
08.05.2020 19:14 # 2
qqyyxx
need to change
08.05.2020 19:14 # 3
talip206
On average, it is recommended to change the gearbox oil at 60 70 thousand km. After all, oil has a life span. It warms up constantly and cools down. The oil change does not cost a lot of money, but if you damage the solenoids because the oil does not change, it will cost you 500 600 pounds.
08.05.2020 19:14 # 4
riderzist
[QUOTE = erdemumut] Hi
I changed it 2 months ago, started roaring between 2500 and 3000 revolutions in the 4th and 5th gears.
I asked the master, because the powdered iron that was broken from the gearbox went in the old oil, it makes humming because the gaps are not full, he said lightly, but it was not exaggerated, but I realized that it was not before.
They said that they can be eliminated by adding but I did not do anything right now.
If there are friends who have had such a thing before and contributed to it, I would be very happy if he can suggest what contribution he cut with the light hum.
good forums ...
08.05.2020 19:14 # 5
erdemumut
thank you friends
