Transmission oil and Solenoid valve replacement fee
08.05.2020 16:52 # 1
mustafacan
Greetings to everyone in the forum. The automatic transmission of my 307 automatic gear I bought from Yenicami HAS automotive alert 2-3 months ago in Sakarya was defective. Although they did not say at all, the master could not notice when I asked him if there was a malfunction. I realized that the problem would be from the combination of oil + electro valve due to the fact that the car was around 100 thousand by reading the experiences from the forums. After I bought 3 lt oil and 2 valves, I looked for an automatic transmission that would be installed. In Sakarya, I left the car to Artan automatic transmission repair shop across from the E-Traffic Zone District Traffic. I made the car in the evening, having made the changes. They said it was okay in their trial. When I try it later and it is still OK. But they said there was a problem with the engine's shape and they told me to go to a workshop. When I picked up the car, when I loaded it on the gas, I noticed an excessive humming noise and not improvement before releasing it. I pushed the car a little and got away from the workshop to test the automatic gear. In order to clean the throat butterfly and check this problem, we saw Ada Çalışkan Otoya Fatih master on the carpenter's Industrial Site, the nails on the pipe plastic that the inlet pipe to the air filter were broken during the oil change and one of the gas inlet pipes of the gas injector was raised. Do you think 200 TL is expensive for only oil and solenoid replacement? (http://www.osmndmn.com/blog/peugeot-307-automatic-gear-fault-hatasi-ve-cozumu.html Here we are talking about a workmanship fee of 100 TL.) How do you think the quality of workmanship of this workshop? mustafacan2012-06-27 13:21:50
08.05.2020 16:52 # 2
fTh206
200 tl is normal I think I gave solenoid + oil change + labor 500 tl in winter & nbsp; "C
08.05.2020 16:52 # 3
berk2309
I gave 550 to the original service.
08.05.2020 16:52 # 4
toga406
labor cost paid only for change is expensive
because oil exchanges make oil stations free Strong> 2 out of 120 tl is 240 tl.
08.05.2020 16:52 # 5
mustafacan
Then I see this fee normal for solenoid and transmission oil. And I keep driving my car calmly :) Thanks for the ideas.
08.05.2020 16:52 # 6
ozger06
Where is the place you would recommend for oil change alone in Ankara. What is the fee? Is it possible to & nbsp; everywhere gas stations? & Nbsp;
