Transmission Oil
08.05.2020 17:50 # 1
Friends how many lt gear oil does our vehicles get?
I changed the gearbox oil, put the service 2lt. Since then, my reverse gear has been shaking out and shaking.
I received help by message from an online peugeot special service.
that person also receives 3 liters of gearbox and says 1 lt is missing. I do not think there will be a problem with your reverse gear. Your oil is missing and your reverse gear passes by shaking and making the gear sound.
If you help, I would be happy. How many liters of oil do you get? 2 lt or 3 lt?
My car is 2008 model 207 petrol.
08.05.2020 17:50 # 2
blue42
This interesting gear oil issue is a complete mystery, I opened this issue too, some call it the spinal cord, some say it goes away for a long time, if you ask the master, it does not want to change it, it will be more efficient to put it on reverse gear.
08.05.2020 17:50 # 3
[QUOTE = Honor] I assume he has 207 by looking at the signature. The vehicle gets 2.1 liters of oil and never overflows. The person who said it takes 3 lt spoke unconsciously. 100 km manual transmission oil life is written in the booklet. transmission oil does not get dirty. however, since the oil is not fully synthetic, its structure may deteriorate after 100 thousand km. so it can be changed. If oil is missing, have it checked. your problem may be caused by fat poor quality or fat thickness. we will help you better if you know which brand oil is put on and what the oil numbers are. [/ QUOTE]
75w80 castrol v fe sytrans oil was put in. 2 lt was put. I also searched the forum. There, a friend wrote that they put 3lt oil in the transmission when he changed the pressure pad. maverick 2013-07-31 22:18:01
08.05.2020 17:50 # 4
[QUOTE = onurazgin] A very good quality oil in all oils. Have you done the process of axle removal in the vehicle ?? If something has been done about the axle, the gearbox may have run out of oil. I say check the oil I [/ QUOTE] did not do any axle operation. I changed the transmission oil so that it could soften the gear shifts. If I knew it would be, would I change it? As the friend in the 207 forum says, is it taking 3lt?
08.05.2020 17:50 # 5
efesbright
The capacity of 207 is 2 liters, not 3 liters. I made it myself 3 months ago, I bought it, I bought it. The reverse gear is doing the same thing to me, but when putting it in reverse, the vehicle must stop exactly. In my opinion, even if the vehicle is not stopped completely, that is, even when it slips slightly. there is no problem when it stops.
08.05.2020 17:50 # 6
friends 207 friends in the forum changed gearbox oil in umraniye garage turkish. I called there in the morning. They always said it was their job. I drained the oil again and put 2.75 lt of mobile 75w80 oil. I hope it will not be a problem.
After putting the oil, I called Umraniye garage folk again. If there is a problem, we always buy 3 lt close to our job.
08.05.2020 17:50 # 7
efesbright
http://www.castrol.com/castrol/sectionbodycopy.do?categoryıd=9041330&contentıd=7074757
http://www.mobiloil.com.tr/turkey-turkish-lcw/carengineoils_which-oil.aspx
It looks like 2lt around here if you want to check my car.
efesbright 2013-08-01 14:05:55
