Transmission oil
08.05.2020 20:11 # 1
akk0212
Good day 2005 model 1.6 hdi I have 307 vehicles at 212000 km. I want to change the gearbox oil. What would be your advice? Vehicle Manual
08.05.2020 20:11 # 2
I would recommend @ akk0212 hocam mobil 75W80 transmission oil.
08.05.2020 20:11 # 3
esstel
manual 2005 model 307 1.4hdi manual gearbox oil change of my manual vehicle ... I said why I have not changed so far ... oily 75w 90 ... the oil that comes out is officially oily water ... you can see the filling area after removing the hair under the battery, you can empty the drain without removing the crankcase protection ...
08.05.2020 20:11 # 4
akk0212
I gave 2 mobile 75w 80 spars, I write the result here when the oil changes
08.05.2020 20:11 # 5
akk0212
yesterday mobile 75w 2 lt gearbox oil reached my hand, I changed it, the oil was not so old, I guess its former owner has changed before, I put 2 liters under the battery.
08.05.2020 20:11 # 6
If the oil is not as thick as the engine oil, if the teacher is old, then the color tone changes when the trouble occurs in the gearbox. Again, there will be a little relief in the chassis.
08.05.2020 20:11 # 7
akk0212
Meanwhile, the gears are softened compared to the past
08.05.2020 20:11 # 8
Oktkor
How many km should this oil change?
