Transmission is running out of oil
08.05.2020 20:22 # 1
Jantiniz
Hello friends, I hit the bottom of the car a little, ten lips are broken and the stop light is on. As if the bottom of the engine also sounds, if the car's voice has changed, do I have a lot of damage? you Janti 2017-05-28 00:26:03
08.05.2020 20:22 # 2
aykutbayram1996
Are you sure you missed the transmission? There is no drip drip, you may miss out of the times I drained it completely, but if you do not pierce the crankcase, you will never run the car and take it to the master.
08.05.2020 20:22 # 3
Jantiniz
Yes, friends pierced the crankcase and the engine's ear was broken and I drove 200 meters.
08.05.2020 20:22 # 4
TUNAYCAN
bro, I am a gearbox repairer, burned because of the leakage of a high-speed oil leak so burn it.
08.05.2020 20:22 # 5
aykutbayram1996
My brother never took it with the tamper-post puller, did not use the engine.
