TRANSMISSION GOES INTO NEUTRAL WHEN COLD
20.10.2023 17:35 # 1
Yusufbabur
Hello dear members, my car is a 2008 model 308 diesel semi-automatic. When I start the car in the morning, the gear always goes into neutral for the first 10 minutes. I give gas and it doesn't work. It fixes itself when I turn the ignition off and on. It does this 5-6 times in the morning. It doesn't give this error when the weather is hot either. After using it for a while, I use it as if there is no problem. If anyone can help, I would be very happy.
27.10.2023 20:40 # 2
Hello sir, have the vehicle's transmission calibrated and also check if the vehicle has given a fault code. What is the robot oil level?
02.11.2023 02:51 # 3
Yusufbabur
Thank you for your interest, Master. Is there anyone you know on the Beylikdüzü side of Istanbul?
06.11.2023 09:05 # 4
[QUOTE=Yusufbabur]Master, thank you for your interest. Is there a master in the Beylikdüzü region of Istanbul who you know?[/QUOTE] You are welcome. https://www.onozotomotiv.com/burayı tarcih is a very popular choice. You can go and see him. I think he is close to you.
09.11.2023 13:45 # 5
Yusufbabur
Sir, I went to Mr. Önder at Önoz Oto, he could not solve the problem.
