Transmission Fluid Change
08.05.2020 20:45 # 1
ORhun53
Hello friends;
My 2006 model feline 206 automatic vehicle is at 120 thousand km.
I want the comments of those who have changed and knows among you before. If you have a place you can recommend in the Anatolian side of Istanbul or in Kocael.
08.05.2020 20:45 # 2
talip206
You need to change the automatic gear. The gear shifts will be better if you buy the oil with a good mobile brand. If you do not change, solenoid valves will deteriorate later.
Unfortunately, I have no idea in the region you mentioned about the master.
08.05.2020 20:45 # 3
akk0212
my intermediate manual 307, I changed the last oil, put it on the mobile, there was a softening in the gear changes
08.05.2020 20:45 # 4
onurrr41
I had to change it when my vehicle cut off the axle. They put Castrol, knocked on my gear. When the oil changed, it became like a DSG gearbox :)
08.05.2020 20:45 # 5
ORhun53
[QUOTE = onurrr41] I had to change it when my car's axle cut. They put Castrol, knocked on my gear. When the oil changed, the DSG gearbox was like:) [/ QUOTE]
Did they change the filter when it changed oil? How much did it cost?
08.05.2020 20:45 # 6
alperucan
I am going to replace my 206 tx vehicle's selonoid valves and gearbox oil filter.
Two cellonoid valves for 250 TL
I bought the filter for 50 TL.
But I have not received Mobil lt 71141 yet.
Does anyone know how many liters of oil are used in total?
08.05.2020 20:45 # 7
talip206
[QUOTE = alperucan] I will replace my 206 tx vehicle's selonoid valves and gearbox oil filter.
Does anyone know how many liters of oil are used in total. Thank you [/ QUOTE]
Normally the transmission takes around 7 liters, but they can only empty about 3 to 4 liters. That's why they add as much as the oil that comes out.
In some places, I heard that they pulled out almost all of them because they vacuumed with a machine. He doesn't do it everywhere.
