Transmission Ear?
08.05.2020 16:01 # 1
kuantum
I will replace the transmission ear of my vehicle. But when I searched for "307 gearbox ear" in google, I could not get an efficient result. does this piece have another name? I could not find the spare parts on the internet. I am looking for the transmission ear for my 2006 model makeup case 307 SW, do you have a chance to give me a link?
There is also a transmission ear brand called "cassix", I think. But I'm not completely sure of the spelling. I searched on Google as sasiks, I searched on sasix I did not get results. What is the original of this brand, is there any idea?
08.05.2020 16:01 # 2
naksi
Let me give you some experience about brother transmission ear, I changed you all how much engine transmission
As a priority, the vehicle has 3 ceit ears, automatic diesel and gasoline manually.
What is your vehicle all different from each other?
Also, the ear for automatic was between 250 and 280 TL. I found it clean from 50 lira and found it clean.
When he pushed the car in 1st gear, he would beat the box now.
If you have any questions, let's answer
08.05.2020 16:01 # 3
g-demir
I think that brand's name is "sachs" :) all the pieces know, don't bother
08.05.2020 16:01 # 4
kuantum
[QUOTE = naksi] Let me give you some experience about brother transmission ear, I have changed all of them in engine transmission.
you may be the person I am looking for. Let me summarize as follows: My vehicle passes from 1 to 2 while passing. there is a slight push forward. It is also forced to the upper gears and passes at high revs. At the same time, when I idle the car while it stops, it puts the car forward slightly but noticeably after about half a second. I researched. It was said that it can be resolved by replacing the transmission ear. an engine said yes it needs to change. The other two masters said no, this looks solid replacement. what should I do? How was your vehicle, how did it change?
08.05.2020 16:01 # 5
kuantum
By the way, transmission wedges write 20 TL or so. But I need the original sachs brand wedge. its price was around 80 TL, right? I couldn't find it on the net but :(
08.05.2020 16:01 # 6
naksi
gearbox wedge 20 25 TL but something that can be pushed forward may be related to the transmission, not the gearbox wedge. If there is no one throw away, the gearbox chock or the engine chock is broken, it makes a click and die, and it does this in series on departure. I think 20 wires are not so much, 20 25 wires workmanship, change the ear to the ear of 50.
08.05.2020 16:01 # 7
kuantum
I received 120 TL for ear + labor. I'm getting. They say that 20 TL is native.
08.05.2020 16:01 # 8
naksi
either ear is not worth 20 lira 100 lira workmanship too
where are you from
08.05.2020 16:01 # 9
kuantum
Istanbul.
08.05.2020 16:01 # 10
kuantum
Meanwhile, the original ear in the authorized service is 160 TL. excluding workmanship.
08.05.2020 16:01 # 11
sahin-peugeot
[QUOTE = g-iron] I think the name of that brand is "sachs" :) all the pieces know, don't bother [/ QUOTE]
SASIC makes brand
08.05.2020 16:01 # 12
kuantum
I went to replace the ear today, but when we turned it on, I stopped replacing it when it turned out that the piece had just been replaced. But there is noise coming from the front right side of the vehicle, and while driving on the road, there is a rattling noise in front of the vehicle, the car is throwing forward. what is going on god sake: ((((((
