Translation of RD3 tapes to the amp output |
| • Homepage » PEUGEOT MODIFIED PLATFORM » How To | |
| 08.05.2020 19:13 | # 1 |
Alicilik |
Today, in our program, I will tell you how our original RD3 coded cd player will turn out the amplifier. The aim of the project is to send the signal to the amp without using the original tape deck. While the aftermarket tapes provide this, the original tapes can only be replaced by software. Your normal 4 channel output converts from the radio to the amp output with the help of pp2000 or diagbox. You can then send the normal audio outputs as a signal to the amplifier. After I have already sold the Pioneer tape of my audio system, 3 RCA cables are free. My previous tape supported 6 channels of audio. I was able to control the ten back and the bottom separately. Now I will carry this to the original tape. For now, I will try to be here with the visual and final video in the article but shortly. The list of materials to be used is as follows: ISo loudspeaker socket (with external socket to be inserted into the tape. RCA Female cable end according to the number of RCA dis. (I will use 6 pieces. It will be on and back + sub. I will also use Sub on the back channel.) Mumkunse 2x1.50 cable (1-2mt is enough) Soldering iron Solder wire Solder paste macaroon Electrical tape . . . . . . . . . . |
| 08.05.2020 19:13 | # 2 |
Alicilik |
Part of the materials, ![]() ![]() ![]() The cable is shaped, ![]() |
| 08.05.2020 19:13 | # 3 |
Alicilik |
reserved.
| 08.05.2020 19:13 | # 4 |
Alicilik |
reserved.
| 08.05.2020 19:13 | # 5 |
Alicilik |
reserved. |
