Transfer issue
08.05.2020 19:10 # 1
R.CaVuS
Even when my friends press the gas when my vehicle is idle where it stops, the tachometer and the vehicle react late, which also affects the performance of the vehicle. What's the solution ?
08.05.2020 19:10 # 2
R.CaVuS
Help ?
08.05.2020 19:10 # 3
R.CaVuS
08.05.2020 19:10 # 4
riderzist
[QUOTE = R.CaVuS] Even when I press the gas when my friends vehicle is idle, the tachometer and the vehicle react late, which also affects the performance of the vehicle. What is the solution? [/ QUOTE]
the delay is too much. If it's too much, you have to go to a master. An application of electronic throttle pedals for fuel saving purposes. I know it is an application to prevent sudden departures in congested traffic at the first departure. it is present in most vehicles with electronic throttle. I also have that late detection as much as a quarter of a second. Your friend has a 2008 vectra. you need to hit the gas half or 1 second before you start. you should get used to this situation. I got used to the friends who used different tools.
If you don't get used to, check out the pedalbox. the price is a little expensive. When selling a vehicle, you can disassemble and attach it to the vehicle you bought.
08.05.2020 19:10 # 5
R.CaVuS
[QUOTE = riderzist] [QUOTE = R.CaVuS] Even when I press the gas even when my vehicle is idle where it stops, the tachometer and the vehicle react late, which also affects the performance of the vehicle. What is the solution? [/ QUOTE]
About half a second. The rev counter is getting up too late. I think the injectors are clogged
08.05.2020 19:10 # 6
riderzist
[QUOTE = R.CaVuS] [QUOTE = riderzist] [QUOTE = R.CaVuS] Friends, even when my vehicle is idle where it stops, the tachometer and the vehicle react late, which also affects the performance of the vehicle. What is the solution? [/ QUOTE]
About half a second. The rev counter is getting up too late. I think the injectors are blocked [/ QUOTE]
Buy diesel injector cleaner get würth from internet. A slight delay is normal and may cause trouble for half a second.
Şurda on sale 20 tl http://shop.wurth.com.tr/dizel-enjektor-temizıcı-150ml
08.05.2020 19:10 # 7
R.CaVuS
[QUOTE = riderzist] [QUOTE = R.CaVuS] [QUOTE = riderzist] [QUOTE = R.CaVuS] Even when my car is idle where it stops, the tachometer and the vehicle react late, which also affects the performance of the vehicle. What is the solution? [/ QUOTE]
I bought the 300 ml one, thank you :)
08.05.2020 19:10 # 8
Mesut48
The sergeant will be off topic, but is it your first diesel vehicle? Was the previous ones gasoline?
08.05.2020 19:10 # 9
R.CaVuS
[QUOTE = Mesut48] Sergeant will be off topic but is it your first diesel vehicle? Was the previous ones gasoline? [/ QUOTE]
My first vehicle :) I have never had a diesel or a vehicle before me :)
08.05.2020 19:10 # 10
Mesut48
The car has nothing to do with delusion :) The diesels are dead in the lower periods,
The inert wolf incident is difficult, especially in a 1.4 car is harder :)
I mean, enjoy yourself, your car is like a cillop.
08.05.2020 19:10 # 11
R.CaVuS
[QUOTE = Mesut48] The car has nothing to do with delusion :) Diesel is dead in the lower revs,
I hope so :) I ordered a motor silk for würth oil for fuel.
