Traction Problem in Car
08.05.2020 17:27 # 1
uyarrr
Friends & nbsp; & nbsp; 2003 model & nbsp; 1.4 HDI XR & nbsp; & nbsp; & nbsp; My
model tool & nbsp; & nbsp; 2-3-4-5 & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; in gear changes car cycle & nbsp; 2500 & nbsp; until & nbsp; car not towing from 2500 rpm - 3000 & nbsp; rev & nbsp; Traction starts until & nbsp; & nbsp; but & nbsp; Requests gear shifts after 3000 cycles & nbsp; with gear up & nbsp; again & nbsp; & nbsp; speed & nbsp; Falling & nbsp; Doesn't take up to 2500 & nbsp; & nbsp; car & nbsp; & nbsp; nearly & nbsp; picky & nbsp; & nbsp; as if & nbsp; 4 & nbsp; & nbsp; gecersıny to & nbsp; in the same position & nbsp; going.
What is this situation & nbsp; what is caused by & nbsp; friends with knowledge of what the cost will be & nbsp; help & nbsp; If & nbsp; I'm glad.
Thank you.
08.05.2020 17:27 # 2
rockwaryumm
[QUOTE = is uyarr] Friends & nbsp; & nbsp; 2003 model & nbsp; 1.4 HDI XR & nbsp; & nbsp; & nbsp; My
What is this situation & nbsp; what is caused by & nbsp; friends with knowledge of what the cost will be & nbsp; help & nbsp; If & nbsp; I would appreciate it.
Thanks.
now I don't understand how my friend wants gear after 3000 dd. It's normal to go down to the lower revs when shifting gears. I've never used your car, but what kind of a fall this may seem to you is not going to be due to the weakness of your car. If this has happened afterwards, try a carbon clean first, and first, do you have the air filter of the vehicle, the bursting cracking hose or something & nbsp; check out
08.05.2020 17:27 # 3
uyarrr
He & nbsp; Let me tell you animate it in your mind & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; assume that & nbsp; you are going up a steep hill 2nd gear & nbsp; If you pass 3 & nbsp; what the car does & nbsp; cycle drops & nbsp; shrink & nbsp; & nbsp; gas becomes insoluble. & nbsp; & nbsp; cents to & nbsp; reverse shifts.
This is the same position & nbsp; & nbsp; & nbsp; on the normal straight path From 2nd gear to 3 & nbsp; go by & nbsp; the other is falling suddenly & nbsp; as & nbsp; car & nbsp; not actual. & nbsp; very slow & nbsp; slowly & nbsp; & nbsp; as if the turtle & nbsp; such as & nbsp; It attracts.
08.05.2020 17:27 # 4
uyarrr
Or I say to you & nbsp; normal way & nbsp; go & nbsp; 2. & nbsp; from gear. 4. What happens if the gear changes the car cycle & nbsp;
I have & nbsp; same as normal nights & nbsp; Happening.
08.05.2020 17:27 # 5
ismailkaya
clutch pad & nbsp; may be dead too high to grip clutch
08.05.2020 17:27 # 6
uyarrr
none grip normal & nbsp; there is no problem in degrading
08.05.2020 17:27 # 7
ismailkaya
If there is a fault in the electronic system, I would warn you that the patrol start ends soon.
08.05.2020 17:27 # 8
uyarrr
Vallala & nbsp; I don't get out of the car & nbsp; but & nbsp; & nbsp; a & nbsp; My friends & nbsp; & nbsp; Turbo & nbsp; and said it might be from injection
08.05.2020 17:27 # 9
istanbullu_3886
If there is oil in the turbo control solenoid valve or vacuum tank at the rear, vacuuming will not be complete and the turbo vestigite will not open completely and the vehicle will be checked if it is oil and if necessary, the vacuum pump must be replaced.
08.05.2020 17:27 # 10
gngburak
Let's see if oil is mixed with cooling water
it may have burnt the seal. I also had the same problem, we installed a new seal.
08.05.2020 17:27 # 11
mistik
It is likely to be from the turbo .. I was throwing the bait back to 2 when I dropped it from 2 to 3 on my vehicle, there was oil leakage in the turbo, everything was improved after the repair, flowing at 3, now even 4 of them + air filter changed ...
08.05.2020 17:27 # 12
yurdakulada
Check the ERG valve, there are two thin hoses connected to the erg valve, see, the hose does not cool in the turbo size when it comes out, I experienced the same. I went to the private peugeot service, they didn't have a place to play with, but there was no sound from every head. I started to search for myself, I entered Germany forums, there was the subject of erg valve. I have changed the master timing set that installed the hoses incorrectly.
08.05.2020 17:27 # 13
savasozturk
ooooo there in the country burdaaaaaaaa "Shocked" welcome dad ..
friends are really experienced in this kind of things in the country. I saw a lot of help .. I will take into account what he said .. They will definitely help with parts etc .. I refer to his opinion about almost every malfunction or part ... I did not see that he was wrong ...
08.05.2020 17:27 # 14
yurdakulada
thank you, fight ...
also have an oxygen sensor.
08.05.2020 17:27 # 15
uyarrr
Your friends comments, your help & nbsp; thank you very well & nbsp; & nbsp; but I'm confused :)
Also mystic & nbsp; our friend & nbsp; & nbsp; ramp & nbsp; He said he was fainting while leaving & nbsp; & nbsp; & nbsp; but my car & nbsp; not ramp & nbsp; on the straight path & nbsp; 1 to 2 & nbsp; 2 to 3 & nbsp; & nbsp; He faints immediately when going from 3 to 4 & nbsp; & nbsp; & nbsp; Almost 2 checks are coming from 3.
Master's one & nbsp; He issued a cost like 1500 TL & nbsp; turbo and & nbsp; I was intimidated by saying injections & nbsp; :)
& nbsp;
08.05.2020 17:27 # 16
yurdakulada
I think it would be better if you find a master who has referrals, maybe there is a small problem, it is not possible to handle 3-5 services without consulting because most of us are the seller, and in our country, the amount of 1500 TL is not even 800 thousand dollars ...
08.05.2020 17:27 # 17
inceyasar
Have a look at the Air Flow Meter with great odds
