Traction problem at 406 gasoline
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:00 # 1
Macenta11
Hello friends 2002model I'm using 406 gasoline is running out, the master showed, float said and renewed, but the problem is in the same way, the car is drowning in gasoline 4 cu gear is hard to enter. Also, there are 180 TL entry fee, there are funny things like they said.
08.05.2020 20:00 # 2
first of all welcome. If the needle of the cloth is not able to play it or not, the display may be defective. or if you buy 20-30 TL how much gasoline you buy, it will not move, at least 50 TL or more gasoline is required. When it comes to the traction of the vehicle, the LPG goes without any problems, but if the petrol is drowned, either the fuel injectors are disturbed due to the rich-poor mixture or the LPG brain (regulator) is defective. When was the last time the filter of the diaper changed? If there is a problem in vits switching, 4-speed secromenci is broken.
