|   | traction problem |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 19:00 | # 1 |
|  rzy.dnz | |
| 08.05.2020 19:00 | # 2 |
|  serdaralisan | |
My friend, you bought the car from my lady, since the ladies do not press the gas, the vehicles get deaf, how much the gas is not going, the car does not go. opened using the vehicle began to come 180 hands easily  | |
| 08.05.2020 19:00 | # 3 |
|  muro_60 | |
It will be done in the turbo, you have to put it in a general maintenance.
| 08.05.2020 19:00 | # 4 |
|  rzy.dnz | |
Thanks for the information you provided, I will look at what you say more than the lady but the officer did not use the engine.  | |
| 08.05.2020 19:00 | # 5 |
|  Faruk | |
[QUOTE = rzy.dnz] Thanks for the information you provided, the vehicle is not just from the lady, but I will look at what you say more than the officer.  [/ QUOTE]  traction should be improved with maintenance of filter oil or something.  If the tremor exceeds 90, if there is a tremor, the motor will come out of the rear wheel balance. if there is a tremor to brake pressure from discs or engine flaps.  First, get a balance in all 4 wheels.  | |
| 08.05.2020 19:00 | # 6 |
|  ismailkaya | |
I would say that they have to change their care for the service.
| 08.05.2020 19:00 | # 7 |
|  samet206 | |
If the speed is increasing, if the speed does not increase, the pressure is depleted on the pad. But as the other friend said, if the car is used at low speeds, the engine is getting embroiled after a certain period of time. After the maintenance, the vehicle will be gathered a little more ...  | |
| 08.05.2020 19:00 | # 8 |
|  rzy.dnz | |
Thank you, thank you, the way of service has appeared to us, I think the lip spolier music installation maintenance, let me take it all together, but the winter is fine;)
| 08.05.2020 19:00 | # 9 |
|  samet206 | |
Well, I think a lot of things like this, if I put a little money aside, it always stays.  | |
| 08.05.2020 19:00 | # 10 |
|  rzy.dnz | |
[QUOTE = samet206] I think that I think a lot of things like a little bit of money.  Thank you, but I will do it in a month. | |
| 08.05.2020 19:00 | # 11 |
|  alihan59 | |
i have 1.4 maşallaah devil ear 2 people on the lead ramps we have no cutting problem intermediate acceleration also work in a flat way to give it up to 170, enough is enough, damage is less, take a little, the rear wheels are blasting, not work
| 08.05.2020 19:00 | # 12 |
|  serdaralisan | |
Friends 1.4 engine 8 valve casing is heavy, there is no turbo flan, I think that it is also used with LPG. The car will become cumbersome. 94 models 106 xsi 1600 8 valves are normally xsi models 94 ones are 1.4 engines, my 1600 sx1 was written, it sees 2 gears 110 in its first license but it hasn't seen any more lpg I pull the engine from 5 to 4 on 170 thousand ramp, but it does not stack up due to the weight of the repair kit with the key set full of repair materials to the brim. If you do not have a vehicle in the room, there is no other problem.  | |
