Traction problem
08.05.2020 18:46 # 1
mefa
Hi friends. Although I am a new member, I have been following our form for about 1 month.
My car is 2008 model 407 1.6 hdi executive black cd. It's been about 2 months since I bought my car. There was no problem with the pull when I bought it. During the feast, esp / asr system faulty followed by depollution system faulty. the cycle did not exceed 3000, but when I stopped and started the vehicle it passed the cycle 3000 until it gave an esp / asr error, but the depollution gave the system faulty failure when I ran it. I went to the service on the road to Sivasta, the turbo is problematic and they said it takes 4-5 hours. I went back to Kahramanmaraşa in that way until Erzincan. Kahramanmaraş stated that the service Egr should change, but we erased the mistakes in the brain and said, "If it repeats for a few days, then let us change." I had to go out and I got that shape, but I had a marked low traction in my vehicle. I was climbing 4-5 with the slope 2. The turbocharger of the vehicle was engaged in 1-2-3 gears, very high 4000, but I did not feel it. The return of Kocaeli gave the same error again. I took the vehicle to the master in the industry. As far as I can keep in mind, 3 of the heat injectors were broken, said the car changed, the car did not improve, the heat sensor did not change, the egr was deactivated, the air flow changed, the turbo air pressure sensor and ventilator, I think it changed, the mosaic filter did not change. The turbo was completely dismantled, the turbo master said there was no problem, the injectors were overhauled, these are the processes I can remember.
Thanks in advance for your comments and solution suggestions
08.05.2020 18:46 # 2
Heavy_Metal
Since the car's frame is heavy, it is normal for the engine to be forced in the traction. I started buying diesel from Shell Nitro Euro diesel on a recommendation. I noticed an increase in traction. There was even some reduction in engine noise. I was very pleased with this fuel. I advise. I started to see the difference 1 month after I started using this fuel.
08.05.2020 18:46 # 3
Heavy_Metal
Let me answer your main question. After writing the exhaust emission system malfunction and asr / esp defective writings, the engine stopped automatically while in motion. It just happened to me. Very frustrating. It repeated repeated malfunctions. Then I changed the fuse box inside the engine and the malfunction improved. Have your car looked at electrical and electronic systems. I had it looked, the fuse box inside the engine needed to be changed, said the master. I changed it improved.
08.05.2020 18:46 # 4
gayetnormal
Firstly, get well soon. When I received an esp / asr system faulty failure and subsequently I received the engine needed repaired error instead of depollution system faulty, I experienced the same things recently. I visited 3 services, they would all change the turbo or something. I pulled in front of the house and started looking at this internet as a turbo. At that time, I realized that there is an invention called an actuator at the bottom of the turbo. Inventing the pin that moves the fins inside the turbo up and down. at the bottom there is a hose that goes to the vacuum box. to the actuator connected by a sponge-like elbow. the sponge has become excessively loose. As a result, air from outside does not form the diaphragm inside the accumulator. Therefore, as the pin does not move, the air in the turbo is not closed and the air cannot pass. I changed that little sponge piece. Now there is neither a fault nor a fault or traction problem in the vehicle. no money came out of my pocket. Your information. check it out.
08.05.2020 18:46 # 5
gayetnormal
the subject is very old, but if anyone is curious, I wanted to inform you that method is method.
08.05.2020 18:46 # 6
noscream
Is there a photo of that part under the turbo in that part you mentioned? Maybe you need it ...
08.05.2020 18:46 # 7
modiemlak
I had the same problem as well, there was no traction drop, but when the warning came out, the engine was not running, definitely get it done from the authorized service, it is guaranteed for 1 year, replace the fuse box, the problem will be solved.
