Traction problem
08.05.2020 18:05 # 1
yener42
Hi guys, I just joined you. When I bought a 407 diesel 2006 1.6 execuvite, when I thought there was a traction problem, the friends said that diesel was not this fast vehicle ... when I got another 407 I realized that my vehicle was donkey .... I went to the service, the turbo was repaired, the egr changed, the injectors were cleaned, the air filter changed Better now, but not like the other 407 but still cumbersome slow problem please help please Car does not exceed 80 in 2nd gear? Sleepy
08.05.2020 18:05 # 2
mev347
What is blgin in the printing pad?
08.05.2020 18:05 # 3
yener42
I said to the service that the pressure can be from the lining. I regret what I said: D I just spent 1500tl to solve this problem but it didn't work :( Could it be useful to add additives to this tank?
08.05.2020 18:05 # 4
mami202
teacher, it will be useful to visit a different service. You have made 1500 liras and still cannot be solved.
08.05.2020 18:05 # 5
Bugra
there may be many reasons. brakes may be stuck, for example. If you want to try to lift the vehicle with a jack, see if the tires turn smoothly.
08.05.2020 18:05 # 6
qqyyxx
Whatever your vehicle is so cumbersome criterion does not exceed 80 in 2nd gear, you are not already using a vehicle that should make 2nd gear 80. You can find a cheaper way to find out if there is a problem with your vehicle's power by going to a robust test center.
08.05.2020 18:05 # 7
KILIC
I think there is no problem in the car. You are expecting a lot. 80 km speed in the 2nd gear is very good. I think the ball has 210 speeds already.
