Traction force
08.05.2020 15:20 # 1
sace
Hi friends. I have 307 vehicles. I have a vehicle for 7-8 months. My car was good up to 3rd gear. 4. And especially 5 rounds of gas, I root out from 110 to 115 difficult, it gets harder and more. Also, after 4000 cycles, it was a strange buzzing sound, so as if I had to go to that noise with 200 :) I took it to the end of last year. I changed it 3 weeks ago, the hum continues exactly like that :) Traction increased slightly. In short, I tried to take it to the master 2 days ago. Then, the muffler pipe was removed under the air filter, the nail was broken, it was repaired, it was tried again, there was no noise. Was the dislocation of that pipe I was wondering affect the traction? Because my master does not affect the traction, it just makes noise, although he says that it does not stop the pressure as if traction has increased. May be psychological .. I'm waiting for your comments ..
08.05.2020 15:20 # 2
goktug
The 1.6 engine cannot exceed 115 for the vehicle only for that reason. If there is a turbo, the problem is in the turbo.
08.05.2020 15:20 # 3
106_arts
Which series of vehicle's 307 gasoline?
115 or something already makes the car in 3rd gear
In addition, the exit of the filter pipe does not affect the traction, the master has said right, of course, if the pipe comes out and does not come into contact with another barrier, because if it is obstructed, the car cannot draw the air, so it will fall.
08.05.2020 15:20 # 4
sace
[QUOTE = 106_arts] Which series of vehicle 307 is simulated?
My car is 1.6 petrol. The current traction of the vehicle has improved well after these operations. As you said, the pipe that comes out may come somewhere and be clogged. I asked a friend these days, pipe out does not affect traction but increases fuel consumption, he said. Thanks..
08.05.2020 15:20 # 5
So did your speed increase?
08.05.2020 15:20 # 6
sace
It has increased noticeably. I touch a little gas acceleration has improved a lot now. I tried in a short distance and saw 150 comfortable.
