Traction Drop With Warming
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models
08.05.2020 19:16 # 1
607 3.0 V6
Hello friends. I had opened a similar topic before. my vehicle 607 3.0 V6 207 hp. My vehicle, which accelerates smoothly at the first start, stacks up with warming and falls out of traction. I hear a high-pitched and louder exhaust sound between 2000 and 3000 rpm. as if the vehicle drops from 207 horsepower to 150 horsepower. I would be very happy if you inform. thanks.
08.05.2020 19:16 # 2
sdttn
Failure codes should be examined with PP2000.
The instantaneous values of the sensors should be checked.
08.05.2020 19:16 # 3
607 3.0 V6
What could be the forecast? Does PP2000 find the solution you call?
08.05.2020 19:16 # 4
sdttn
He finds the solution master.
PP2000 tells him what's going on in the engine.
Are there any messages on the screen? Does it start when the temperature indicator returns to normal?
Is there LPG in the vehicle?
08.05.2020 19:16 # 5
607 3.0 V6
yes call. lpg li. There is oil temperature on the left side and there is a temperature indicator on the right side.
08.05.2020 19:16 # 6
berk2309
Usually in peugeot, because of the cooling problems, there is a leakage in the vehicle. Is the vehicle automatic?
08.05.2020 19:16 # 7
ismailkaya
electrical socket of the bobbin, spark plugs, injectors, air filter, and catalyst cleaning
08.05.2020 19:16 # 8
sdttn
If the speed does not increase while the speed is increasing, check the gearbox.
08.05.2020 19:16 # 9
607 3.0 V6
yes the car is automatic. As the speed rises, the speed does not increase, as you said. Maybe that is why we will change the rear silencer.
08.05.2020 19:16 # 10
mmt kck
You changed the gearbox oil last time. When the heat of the transmission oil increases, the kidnappings may begin. mmt kck 2015-05-17 22:57:31
08.05.2020 19:16 # 11
berk2309
If the gearbox is automatic, check the pressure values and temperature.
08.05.2020 19:16 # 12
sdttn
[QUOTE = 607 3.0 V6] yes, the car is automatic. As the speed rises, the speed does not increase as you say. We will change the rear silencer, maybe that may be the reason.
Make this situation clear and do not waste money.
Note the speed when it is cold in the same gear at the same speed.
Note the speed when it is hot in the same gear at the same speed.
Let the road be the same.
The obvious difference is the gearbox.
08.05.2020 19:16 # 13
607 3.0 V6
There was a problem with the gearbox as well. 2 years ago, the vehicle had distributed the gearbox. it always knocks in reverse gear. Could it have anything to do with it?
08.05.2020 19:16 # 14
sdttn
Why then, when it got warm, its performance started to decrease?
Right after the transmission?
sdttn 2015-05-18 00:18:09
08.05.2020 19:16 # 15
607 3.0 V6
I do not remember very well, but after the breakdown after the vehicle, there was no problem. But I do not remember very well.
08.05.2020 19:16 # 16
sdttn
If a process (timing etc.) has been made recently,
If the oil change time is near / came, you can change the oil.
08.05.2020 19:16 # 17
607 3.0 V6
new maintenance was done to the vehicle and spark plugs were changed. We changed the timing when we bought the car 3 years ago. the exhauster said that the rear silencers should be replaced.
08.05.2020 19:16 # 18
atabey23
GOOD EVENING FRIENDS. 2000 MODEL 607 220,000 KM AT 3.0 STANDARD WHAT A VEHICLE.
IT WAS VERY PLEASED, BUT I DON'T STAY 406 MI OR 607 DO YOU HAVE. VEHICLE AUTOMOTIC.
29.09.2024 21:24 # 19
607'ci İmam
Good day, I wonder if you were able to solve the problem. I have been struggling with this problem for 2 weeks.
