TOWING RIGHT AND VIBRATION
08.05.2020 17:53 # 1
uslu5421
I have a 2005 model 307 look vehicle, there was a tremor at 80/90 km, and the vehicle was going to the right when I left the steering at low speed. The service changed because there was a problem on the right axle. There is a skew on the rear axle, it is corrected by pulling on the chassis, the rod balance is made again, but the pull still continues.This time, after 120, the steering wheel visibly vibrates. Burak044 2013-08-22 21:27:23
08.05.2020 17:53 # 2
error
My teacher is likely to have a problem with swings or swing bushes, and it is a little costly to knock on the door of the authorized service for problems that cannot be easily diagnosed, so it can be resolved directly.
08.05.2020 17:53 # 3
fatihgg
Can there be a problem with the rims? rot arms etc ... by the way, I got my car at 110, I put it in the balance of the rod rot balancing three times, the last tire was built properly for your knowledge.
08.05.2020 17:53 # 4
Bunyamin.Kar
Sir, show a couple of different rotbalans, don't stick to one, then you will be victims like me
08.05.2020 17:53 # 5
uslu5421
Thank you guys, I will evaluate all the options you have given, and write the result here. LOL
08.05.2020 17:53 # 6
ErolSs
I had the same incident except for pulling my brother to the right.
08.05.2020 17:53 # 7
uslu5421
Friends, the problem is solved:) As I was afraid, my vehicle was not accidentally. There was curvature on the right rim. So I needed 4 wheels + tires alone. Thanks to the friends who gave ideas. Approve
08.05.2020 17:53 # 8
[QUOTE = uslu5421]
I have just seen the subject, I am glad that the end is solved. If there is a skew in the rim, it does not have balance, it does if the rims that are put in later are not compatible, it does not put a bracelet in it, if there is a problem in the brake discs, it does when the brake is applied. Smile
dogan106 2013-10-22 13:40:56
08.05.2020 17:53 # 9
uslu5421
Thank you, teacher. The service says the wheels on my vehicle are not original: (Unfortunately, the modified one. Now I am looking at 4 wheels in good condition.
