Tower tensioner & shock absorber
08.05.2020 14:01 # 1
Emin
Another application frequently used in a modified car is the shock absorber tower tensioner assembly. Tower tensioners are used to join the shock absorber towers mutually into one piece.
The purpose of the tower tensioners is to minimize the stretching that occurs in the shock absorber towers, especially in hard bends. The damper towers normally flex when cornering, resulting in some traction loss (or some weakness in handling). Since the tower tensioners are designed to prevent flexions that occur in the shock absorber towers, they divide the energy by taking it from a single tower where the power is loaded and transmitting it to the other tower during cornering. This helps keep the rims parallel to the ground, which helps the tires touch the ground better. As a result, traction and handling are improved during cornering.
When Should Shock Absorber Tower Tensioners Be Mounted?
Although the performance to be obtained after installation is not related to the mileage on your car, if you are a sports car owner, I recommend you to install the front strut tower tensioners at least on the first day you get your car. However, other than this somewhat optional situation, there are certain situations where shock absorber tower tensioners must be applied.
Regardless of whether the tower tensioners are front or rear, they must be applied when switching to larger wheel / tire combinations. Modifications to affect the suspension system, such as changing tougher and shorter sports springs, tougher and shorter sports shock absorbers, or to a larger diameter rim (hence thinner profile tires) ultimately increase the load on the shock absorber towers and even the entire chassis. At the end of all these applications, the stretching on the chassis will be much more than before. Here, the tower tensioners to be applied after these modifications will not only support the chassis and reduce stretching, but your steering will be more sensitive and will respond to the commands you give more quickly.
What Do Bend Rods Do?
As a rule of physics, cars lie on one side only (towards the outside of the curve) during cornering. The anti-roll bars also help to improve the grip of the entire car by pressing the wheel on the inside of the bend (opposite side on the same axle) to the ground. Thus, front and rear slippage is less experienced.
They work in full harmony with the shock absorber tower tensioners, especially in bends entered at high speed. However, there is a disadvantage in the use of land that only one tire remains in the air.
08.05.2020 14:01 # 2
A.L.P
Thanks for sharing.
08.05.2020 14:01 # 3
smttali
thanks for sharing buddy
08.05.2020 14:01 # 4
hasimayaz
There is also an event called Cage, which is used in all rally vehicles for both flexing and safety.
08.05.2020 14:01 # 5
HakanGokdemir
Thanks Emin and Haşim ...
08.05.2020 14:01 # 6
Ismail
Thank you, health
08.05.2020 14:01 # 7
thanks for sharing
08.05.2020 14:01 # 8
kann87
my foster brother leaves a roll cage to our vehicles early duh: DD
08.05.2020 14:01 # 9
hasimayaz
[QUOTE = kann87] adversary brother roll up the cages to our vehicles early on: DD [/ QUOTE]
I think if I say "I hope we will see them in those days" I would have done something right. Big smile
08.05.2020 14:01 # 10
hasimayaz
Mounting stages for friends who are interested in the subject:
Although the tower tensioner assembly seems simple, it can sometimes cause problems from unusual points. Even diesel engines require complete torture, complete Air intake replacement. Even if the wrong battery is used in some 206's, it may be necessary to slide the cabin. In this article, we will describe an omp tower tensioner with pictures.
We mark the damper seat with the tape by aligning the swept edge facing the front.
We drill a hole from the point suitable for the sheet with 4.5 cm drill dump
we mark both sides of the hole vertically.
We align the top with the hole by aligning our lines. Our hole (with a solid hacksaw) takes the form of a channel.
We cover the cut parts of the sheet with roving.
We finish the process by assembling our tensioner. We keep the path of a robust rot master who understands the job for tuning.
08.05.2020 14:01 # 11
A.L.P
brother, you have your health sagi.ii illustrated expression
08.05.2020 14:01 # 12
Carmania
Thanks for sharing
