Torsion Removal hk.
Homepage » PEUGEOT MODIFIED PLATFORM » 106
08.05.2020 19:09 # 1
Mnc106
Friends, after I bought a new tire set, I am rubbing while a person is sitting in the back.
08.05.2020 19:09 # 2
kopiiilcan
Here you go. Torsion removal is expensive but they say.
08.05.2020 19:09 # 3
Mnc106
If the lathe work does not work, the cost is 100-150tl I hope it will not make me sad.
08.05.2020 19:09 # 4
superyusuf
why are you playing with torsion? noluyo tire or surtuyo case
Does the tire fit towards the top of the tire?
08.05.2020 19:09 # 5
samet206
If you are satisfied with the height of the vehicle, you can make torsion hardening, you do not need to lift to avoid driving, if not, then the lifting method can be used.
08.05.2020 19:09 # 6
serdaralisan
friends, I have 106, I had lowered 55 sidewalls, but when I put on the 60 sidewall again, when a person got on, the tires are rubbing and not like that. I will leave a Saturday and leave
08.05.2020 19:09 # 7
superyusuf
I have 45 sidewall tires ...
I got the rear wheels to the turner. It took 0.5 mil from the inside.
then the problem went on.
the casing does not bend to the tire, but zero to zero tire and bodywork
08.05.2020 19:09 # 8
Mnc106
[QUOTE = superyusuf] I have 45 sidewall tires ...
My good friend makes more sense than where to get 0.5mm torsion from the rim
08.05.2020 19:09 # 9
superyusuf
pick up from the side of the rim, where the bjjoes are connected ...
08.05.2020 19:09 # 10
serdaralisan
those 5 miles from inside, you said my rim is almost 5mm from the rear side of the chassis.
08.05.2020 19:09 # 11
superyusuf
Well, I don't know.
