Torsion improvement
08.05.2020 21:05 # 1
srrssr
I have a suggestion to friends who have a torsion problem, you know, the ball will break down and break the shaft, post torsion complete fill, turn off, buy a new bearing or change the shafts or something, costly and long time, you will experience the same failure again, I tried something simple but different, myself, long I have been using it for a long time. I wanted to share it, whether you want to apply it or not. The advantages are of course. I say not to stay.
Then I'll add some photos.
08.05.2020 21:05 # 2
GokhaN
add, let's see, I was curious 106-206-306 users the most tidy thing is torsion
08.05.2020 21:05 # 3
talip206
We eagerly await Clap
08.05.2020 21:05 # 4
ooo, I was very curious, let me see if I have a detailed understanding, it would be nice.
08.05.2020 21:05 # 5
x571
So let's add
08.05.2020 21:05 # 6
Aykutemre92
Guys are off topic but does anyone know about the braking system in the 206's?
08.05.2020 21:05 # 7
srrssr
As friends are in the photos, we use this yellow material instead of a ball bearing, that's all, there are those who do something very simple, this yellow material is not mormal plastic, it does not wear crush.
08.05.2020 21:05 # 8
srrssr
https://resimyukle.xyz/i/qxz54w
08.05.2020 21:05 # 9
boruc
I think the material called material kestamit (cast polyamide).
It is not possible for it to be stronger than the bearing,
08.05.2020 21:05 # 10
srrssr
Of course, the bearing should be stronger, as long as it does not get water and oil, and the bearing should not be worn. , I have been using it for 1 and a half years, and I have installed torsion shafts in bad condition, the roads of the district I am in are shabby, The extra cost is very low, the assembly is simple and you do not pay 800-1000 pounds of torsion.
08.05.2020 21:05 # 11
talip206
interesting. Where can we get this? And of course, even if this process makes a lot of sense, how do we get our masters to accept it and have it installed? Smile
08.05.2020 21:05 # 12
srrssr
Take out my master bearings, you will say plug them in: D If you can disassemble it, you will install it yourself, I will help you with the material, no problem.
08.05.2020 21:05 # 13
Designbyonurkaya
Hi aleyküm, where do we find the materials you mentioned?
08.05.2020 21:05 # 14
srrssr
You can find metal products in places that sell, hod. The price varies according to the size, weight and quality of the material, 70 mm diameter, 30 cm length material is enough on both sides, but there are dimensions, the tolerance of the material to be made, if it is processed incorrectly, it makes a tab if it is tight, loose like a cut spring. If it makes a sound, it will make a torsion.
08.05.2020 21:05 # 15
Ahmetaltan
Hi
Who did you have these parts installed? Did you install it yourself? The same problem started in me and I am in Bursa.
08.05.2020 21:05 # 16
srrssr
Teacher, my neighbor lathe in the industry gave him the measurements he made, I made the installation myself, but I am in the remote district of Bursa and I am 100 km from the center.
08.05.2020 21:05 # 17
Designbyonurkaya
[QUOTE = srrssr] Sir, my neighbor lathe in the industry gave him the dimensions he did, he did the installation myself, but I am in the remote district of Bursa and I have 100 km from the center. [/ QUOTE]
Reis, can we find this material? What is the price? How can you help? What is the total cost?
08.05.2020 21:05 # 18
srrssr
Sir, you get the material of 70 mm diameter 30 cm length from the barrier that sells metal products, the name of which is called as the cruciate, we will contact you after setting up your lathe. .
08.05.2020 21:05 # 19
kod06
Have friends been able to learn the measurements? Tornaci repairman money, if everything knows missing the ready measure, I would be very happy if it helps, let's get rid of getting on the cart now WackoLOL
08.05.2020 21:05 # 20
KillaLee
For those who know the following measures, Or if the friend who made this goes to the forum, please enlighten us
Page : / 2
