TORSION AID!
08.05.2020 19:58 # 1
ziya alp
My friends are constantly disrupted, this torsion has a creak, every part of it, but I do not have the chance to solve it completely. There is no creaking right here, is there any solution? We are tired of giving money every 2-3 months.
08.05.2020 19:58 # 2
Adem Kurtuldu
Lubricate the torsion, was it my brother, my belly, my belly, and when the fat was greased, it temporarily stopped sounding for a while
08.05.2020 19:58 # 3
ziya alp
I am overwhelmed now I am sworn in adem brother, the sound is cut, but it does it constantly, in a few months we will make it fat
08.05.2020 19:58 # 4
Adem Kurtuldu
Well, brother, I can't call him something, it depends on the way you use it.
08.05.2020 19:58 # 5
samet206
These systems are deformed over time and have a problem that is torsion, but after maintenance is not properly done, you will not have any problems. In what case is there a problem of not keeping order in tenths? The size of the rim tires is important in these.
08.05.2020 19:58 # 6
ziya alp
no problem in the front set rim 14 inch tires 175.65.14 we bought a new stone tassel city, some places are still in the asphalt bde bosch service. I have no problem but it started to be a very limiting situation :)
08.05.2020 19:58 # 7
Well, what parts of the process did they change what torsion.
08.05.2020 19:58 # 8
ziya alp
they have done the last torsion sign in the file this is in the file 94 TL repair money 51 TL was bought at 171 TL with a total vat bosch serviced
08.05.2020 19:58 # 9
ziya alp
güncelll
08.05.2020 19:58 # 10
ziya alp
nobody has any comment? About this topic.
08.05.2020 19:58 # 11
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=39660&title=peugeot-206-torsiyon-macera
08.05.2020 19:58 # 12
mbsb44
bro, torsion, just a situation, these squeaks will increase as the beginning progresses, the sound will increase and when you enter the corner hard, there will be voices from behind. The solution must be a good master and a good lathe. The rear axles will be removed completely, the torsion arms will be removed, the old shafts will be removed, then they will go to the lathe, and the new shafts will be driven.
08.05.2020 19:58 # 13
mbsb44
If most of the workmanship is not available, the material is 80 pounds. these transactions are 500 liras at best today. May Allah help you.
