torsion
08.05.2020 18:35 # 1
Ender DOGAN
Hello friends 206 My XT vehicle started to sound from the left back wheel, while I was going to hit the wheel like a find, it sounds like it is sounding at the time.
08.05.2020 18:35 # 2
jack67
Those in Istanbul will help. My advice is to let the lathe go to you. If the shafts are worn, they weld and fill, but they are not performing very well.
08.05.2020 18:35 # 3
ahmed206
Maybe it's 50 TL
08.05.2020 18:35 # 4
menajer
Let's make the back 100 tl instead of torsion.
08.05.2020 18:35 # 5
Ender DOGAN
I hope the cost will be a little bit good nowadays, I am in hospitals, is there a place that you would recommend continuously? the sound disappears when you turn to the right, but there is sound when turning to the left?
08.05.2020 18:35 # 6
menajer
If it is over, I can guide it in Istanbul
08.05.2020 18:35 # 7
Ender DOGAN
yes i am in istanbul
08.05.2020 18:35 # 8
menajer
Maltepede minubus street, I will write the card in the car tomorrow.
08.05.2020 18:35 # 9
Ender DOGAN
Thank you
08.05.2020 18:35 # 10
menajer
You're welcome, see you
08.05.2020 18:35 # 11
tetik-soner
05424370793 is a master craftsman, umraniye is a good master in industry.
08.05.2020 18:36 # 12
madblueblacksea
[QUOTE = jack67] Those in Istanbul will help.
I agree exactly. They want 100 + 100 TL filling and workmanship. The new ones are 80 TL (double price.
may be in the seals that serve as a bearing to the torsion bar, but nobody is evaluating this, they are downloading the direct torsion because money is required :)
If you get into torsion, I suggest you make it air conditioned and periodically lubricate it.
madblueblackse to 2014-06-05 18:10:23
08.05.2020 18:36 # 13
outlaw
YOU CAN THINK ABOUT THE BREAK, BUT LOOK AT THE EXHAUST AND MAKES SOUND SOUND WHEN THE WEDGE TIRE COMES OUT ...
I HAVE A SOUND FRIEND FROM THE BACK WHICH I WOULD SHOOT THROUGH WHEEL THROUGH TESION DISTRIBUTED TORSION DISTRIBUTED I SURVENED UNDERWEEN THERE WAS A HOLE WHEEL REMOVED THE EXHAUST.
08.05.2020 18:36 # 14
yawruaslan
[QUOTE = trigger-soner] 05424370793 veteran ümraniye is a good master in industry ... if you want to see ... [/ QUOTE]
+106
08.05.2020 18:36 # 15
ercn86
I had a squeaking in 106, I did the lubrication, the sound was cut off, thank God I looked for the master, the suggestion of the man is that when I say that my lift is full I will burn that car if you do it for free :)
08.05.2020 18:36 # 16
Ender DOGAN
I do not think from the exhaust, as if the two iron hits each other in the rear wheel home
08.05.2020 18:36 # 17
madblueblacksea
The iron hitting each other on the back is usually a bar. Remove the left rear tire and check the 13 bolt holding the anti-roll bar. If it is loose, the anti-roll goat is broken and it does not loose the bolt due to stretching. If it stops sounding for a while after tightening, you have found the problem. Experience is not hard estimate information. Method to pinpoint the problem, not the problem. The answer is fix when you go to the repair shop and say the back side of the peugeot sounds. Torsion is broken, prepare 500 600 TL. Do not trust the master who made the final judgment without looking.
While working in the industry in time (in 2001), we had such a training with the best master of the industry, to know my experience. We tested it and my thesis was correct and it fired me (because the winter period and things were sluggish, he was giving each employee one week in a row, I was the first to be appointed with atisma and I did not go to work again)
I mean, until the bio in experience. Judging without looking at it is against art. It is experience to say that a woman giving birth to five girls is a girl for the 6th pregnancy and the possibility that this is not a rule is that it is a male and twin quintile. ...
08.05.2020 18:36 # 18
madblueblacksea
What did I write boredom is here
08.05.2020 18:36 # 19
candanxyz
You wrote well :) I do not know the name of the white painted things that we pass by when we go into the wrecks.
08.05.2020 18:36 # 20
Ender DOGAN
I hope it's a little bit of trouble
Page : / 2
