Tool Detector
08.05.2020 20:52 # 1
kayaca
On the internet, I saw an ECU diagnostic tool interfered with Android via Bluetooth, I decided to buy it.
would it be harmful when you put it in the car or something
08.05.2020 20:52 # 2
onlycihan
Many people bought the same product. When you are done, remove it from the OBD socket. If the only problem is stuck, it will run out of battery. I didn't have any other trouble about it
08.05.2020 20:52 # 3
Furkan979
I use peugeot, there is an antipollition problem caused by LPG. If I bought it to delete it, it shows the fault and it is possible to delete the fault.
08.05.2020 20:52 # 4
kayaca
[QUOTE = Furkan979] I am using peugeot, there is an antipollition problem caused by LPG. If I bought it to delete it, it shows the fault and it is possible to delete the fault.
I am constantly malfunctioning the light, because of the LPG and the oxygen sensor, my catalyst is empty, so can it ripple at idle?
08.05.2020 20:52 # 5
tigrap
When I think about ordering, I share the results on a good subject.
08.05.2020 20:52 # 6
Furkan979
I don't know the idle ripple, but it shows and deletes all error codes so don't worry about it
08.05.2020 20:52 # 7
kayaca
I delete it in the service as well then there is no more way to prevent it completely?
08.05.2020 20:52 # 8
kayaca
Is it a problem if we do not remove this device? will he run out of battery?
08.05.2020 20:52 # 9
[QUOTE = rock] Is it a problem if we do not remove this device? will it drain the battery or something? [/ QUOTE]
I don't think it will be a problem, brother, I have never had a porblem on my 206 vehicle for 2 weeks. what is the amperage it will draw Smile
08.05.2020 20:52 # 10
kayaca
I said the material came, I said 10 number valla, I solved the features and I liked it too much.
08.05.2020 20:52 # 11
kayaca
[QUOTE = sonerkyl] [QUOTE = rock] Is it a problem if we don't remove this device at all? will it drain the battery or something? [/ QUOTE]
I thought so, my teacher, the led is on just what it will be that if you look at it, when we lock the car, the red of 4 lights is on and on.
08.05.2020 20:52 # 12
kayaca
At noon, I put it on, and let's see what the evening will be on the way home or the battery will run out or the device will explode :)
08.05.2020 20:52 # 13
tigrap
[QUOTE = rock] material came, I just said 10 number valla I solved the features and I liked it too much, I would like to remove it if the fault is not left, because the cover is closed when the floor is empty as it will be a problem. [/ QUOTE]
There are different varieties, which one did you use?
08.05.2020 20:52 # 14
dou
Can you send the link of the place where the device is sold?
08.05.2020 20:52 # 15
kayaca
[QUOTE = tigrap]
I used torque lite, then I downloaded the license of the torque itself, I did not remove the device, no fault or something directly wipes
08.05.2020 20:52 # 16
kayaca
[QUOTE = dou] device can you link to the place of sale how much is the price [/ QUOTE]
08.05.2020 20:52 # 17
kayaca
when I press the rear window ice remover, it sounds like a click, but it doesn't open the back.
08.05.2020 20:52 # 18
luridline
There may be breakage / rupture in the rear resistances. Take a look. There may also be an invisible refraction. It may result from the installation going to the rear window.
First, check the socket to the resistance, clean and reconnect it.
08.05.2020 20:52 # 19
onlycihan
I think it wouldn't be a problem to use the vehicles that are used daily or two times a week, and it will fill the battery in every study.
08.05.2020 20:52 # 20
luridline
Exactly. They said the power of 0.75 watts, but the product made in china may not be healthy to wear all the time. In case of a possible malfunction of the device, the vehicle will not be damaged. They said there is current protection, but I don't know how good it is.
Can we reset the BSI to factory settings with this module I want to ask
Page : / 2
