Took 206 water |
| 08.05.2020 17:10 | # 1 |
fxmen |
| 08.05.2020 17:10 | # 2 |
same problem happened to me I'm waiting for comments
| 08.05.2020 17:10 | # 3 |
My teacher who bought a lot of water is 5 cm, go to a washer, hold water cannons,
| 08.05.2020 17:10 | # 4 |
KenBlockJR |
taking in door wick chronic in 206s
| 08.05.2020 17:10 | # 5 |
I had the same problem, the ceiling lamp was getting from there, I had the water removed in my car and I saw that the parts inside were moldy, the same problem did not repeat after the parts changed. I also changed the antenna, probably water was going down from the sides of the antenna into the ceiling lamp.
| 08.05.2020 17:10 | # 6 |
peugeotttt |
probably from the door wicks. Check the door wicks. If there is tear, tear, rupture or something.
| 08.05.2020 17:10 | # 7 |
Barut |
in the previous 206m it was taking from the door wick.
| 08.05.2020 17:10 | # 8 |
fxmen |
Thank you to all the friends who wrote the comments, I checked the door fins, I did not see a problem, but I took it out and put it back on and it started raining now and let's see what happens next morning.
| 08.05.2020 17:10 | # 9 |
peugeotttt |
Check out the glass wick and consider any possibility. Meanwhile, I showed the corlu of Tekirdag Palace this evening TV. There is a lot of rain overflowing the brook creek due to precipitation.
| 08.05.2020 17:10 | # 10 |
fxmen |
From 7 am to 10 am, there was a heavy rain in the morning, and it started raining, but the stream broke all the time. & nbsp; |
| 08.05.2020 17:10 | # 11 |
peugeotttt |
You wouldn't cover it if you didn't have a construction.
| 08.05.2020 17:10 | # 12 |
mev347 |
water enters through the holes of the side door laths. It fills between the inside of the door. If you control it with your hand at the bottom, there is a small hole. My advice is to ensure the waterproofing of the door slats. I write as someone who happened to you ... :)
| 08.05.2020 17:10 | # 13 |
fxmen |
[QUOTE = peugeotttt] it wouldn't be anything.
| 08.05.2020 17:10 | # 14 |
fxmen |
[QUOTE = mev347] water enters through the holes of the side door laths. It fills in between the inside of the door. If you check it with your hand at the bottom, there is a small hole. My advice is to ensure the waterproofing of the door slats. I write as someone who happened to you ... :) [/ QUOTE] thank you for your suggestions |
| 08.05.2020 17:10 | # 15 |
I checked the door wicks now, I checked the ceiling lamp, it looks like there is no problem.
| 08.05.2020 17:10 | # 16 |
206 is a chronic problem to take water I don't know if there is any other place you need to check from the ceiling lamp, the door wick or the gasket of the last radiator, but I have not seen the wick, but the other two solutions are simple but annoying.
| 08.05.2020 17:10 | # 17 |
He was taking the water from my ceiling lamp. I disassembled the radio antenna and bought a new leg (10TL) and filled the silicon nicely (good quality) and mounted it on the ceiling again. Then there was no water problem. The antenna is for aesthetic look. The antenna on the ceiling is of no use to the radio. Because the main antenna & nbsp; functions & nbsp; chassis.
| 08.05.2020 17:10 | # 18 |
metin |
it seemed to me that the water level had risen and flowed into the vehicle, as the drain hole under the door was clogged from the glass wick of the door.
| 08.05.2020 17:10 | # 19 |
ii at night, look at the water area, look at the right oly bowl, remove the hood & nbsp; there is a drain hole on the bottom of the plastic assembly & nbsp; there is usually water from the fluffy leaf, or the water is shrinking from it taking water from the air inlet fills the right passenger side & nbsp; this appears on all brand vehicles & nbsp;
| 08.05.2020 17:10 | # 20 |
fxmen |
[QUOTE = text] it seemed to me that water flowed from the glass wick of the door into the door and the drain hole under the door was clogged and the water level increased and flowed into the car. The nail is filled into the door between the yagur and it fills in it. The solution is filled.
