Too Hot error radio
08.05.2020 17:21 # 1
silivriserdar
My tape also comes up with a text like this, and the sound is not turned up, I wonder what the volume is going up to 5. >
silivriserdar 2013-02-12 12:49:40
08.05.2020 17:21 # 2
silivriserdar
Help one of your friends otherwise I'll have to go back to the second.
08.05.2020 17:21 # 3
Alicilik
If it happened after the operation on the door handle, it is likely to be related to it. Take a column and see.
08.05.2020 17:21 # 4
silivriserdar
It is not difficult to remove it, it is not difficult to remove it, even when the master unscrewed it unscrewed 4 screws, and the screwdriver of those screws is not a special star or screwdriver. silivriserdar 2013-02-12 13:14:06
08.05.2020 17:21 # 5
Alicilik
[QUOTE = silivriserdar] Very & nbsp; It is not difficult to be removed even when the master is dismantling, he unscrewed 4 screws and he is not a special star or screwdriver in the screwdriver of those screws. [/ QUOTE]
Columns aren't that hard, if the master has dealt with me. The key you call is the torque wrench. probably 25mm torque. I hope it comes from there and it will recover. I say, take a set of fuel for the fuel you will burn there, it will be useful for you in the future.
08.05.2020 17:21 # 6
silivriserdar
Exactly you are right, it is not very far, but I need to buy the key set. Thank you I am going now.
Yes, the problem is short-circuited, so it was too hot, so it gave a very hot error. silivriserdar 2013-02-12 13:57:41
08.05.2020 17:21 # 7
Alicilik
Get well, everything is hidden in a small detail, just look in the right direction Wink
08.05.2020 17:21 # 8
silivriserdar
Thanks very much
08.05.2020 17:21 # 9
Tamer0671
Selam Aleyküm gives the same error when we work full power for 4 hours, but after it cools down it goes back. This error happened to us after I connected two pillers behind.
08.05.2020 17:21 # 10
berk2309
Have you connected two extras behind or have you changed the two doors
08.05.2020 17:21 # 11
Tamer0671
we tied two extra reports in back & nbsp; backs & nbsp; happened after connecting & nbsp; 700w & nbsp; goldmaster 4 way & nbsp;
bidet left door was broken, we changed it & nbsp;
Tamer0671 2015-05-08 00:00:27
08.05.2020 17:21 # 12
berk2309
The original tape you have is not able to remove it, but the extras usually write information like 4x70 etc. at the top of the tape.
