TO STOP
08.05.2020 19:57 # 1
CVT
My Peugeot 106 QS vehicle stops when the gear is idle. Idling is rising and falling. Can I use old people to help and change the fog light myself?
08.05.2020 19:57 # 2
Cyrus35
I did not understand from 106, but if they have an idle engine, it can be from him.
08.05.2020 19:57 # 3
CVT
There is no problem with the turns, usually when it is wasted in red light or in traffic.
08.05.2020 19:57 # 4
Just like our friend said, have the throat butterfly cleared. lpg no tu if i don't remember wrong in your car
08.05.2020 19:57 # 5
CVT
I have a lpg, does it? I did not have this problem in lpg cars that I used before.
08.05.2020 19:57 # 6
Exactly there is a problem with Cevat LPG settings. I had focus. 2004 model stopped when it wasted like you. I had found a good master, as a result, the atikci made an adjustment, neither the fault lamp was turned on the vehicle, nor the idle imbalance nor the stop.
08.05.2020 19:57 # 7
CVT
Could you send me the address, I will see you tomorrow, I will have the front team and the maintenance of the car you said.
08.05.2020 19:57 # 8
CVT
I am at work right now. Let's go home.
08.05.2020 19:57 # 9
just use gasoline for a while
08.05.2020 19:57 # 10
I went a couple of times and hopefully it corrected the problems.
https://www.google.com.tr/maps/@39.9357798,32.7165607,3a,75y,169.67h,80.08t/data=!3m6!1e1!3m4!1swvfa7b-vyg7sgva-y1otlw!2e0!7i13312!8i6656! 6m1! 1on1
08.05.2020 19:57 # 11
CVT
I will report the situation tomorrow, I hope it is such a small thing.
08.05.2020 19:57 # 12
dogan106
The reason is that the throat butterfly is dirty because of the tactical air filter, you need to use the original air filter and make the connections strong, they clean 50 liras and clean it, and then clean the next ones by making it more in winter.
08.05.2020 19:57 # 13
CVT
Yesterday I went to the surprise gas adjustment was done, the throat butterfly was cleaned, the starter engine was maintained, the problem continues, but normally it would stop 4 times until it went to work, now it is 1 time. .
08.05.2020 19:57 # 14
well, let's see the answer, hopefully when the idling engine changes
08.05.2020 19:57 # 15
CVT
I hope it costs more, the car will do it slowly.
08.05.2020 19:57 # 16
CVT
I wonder if I can find it with the original 106 air filter box
08.05.2020 19:57 # 17
Thumbs Up
http://www.peugeotmarket.com/peugeot-106-hava-fıltre-kutusu-orjınal,pr-3120.html
08.05.2020 19:57 # 18
CVT
box tube is not all one
08.05.2020 19:57 # 19
[QUOTE = CVT] box pipe is not all one, I guess it is not [/ QUOTE]
unfortunately i don't have full information but i guess all of them are sold separately and you have to call and ask
08.05.2020 19:57 # 20
CVT
idling engine changed, gas adjustment was done, winter maintenance was done, spark plugs changed, stop not improved, does this problem from map sensor?
