To apply the parking brake too much
08.05.2020 16:54 # 1
FeverDog
Hello friends :)
I gave my car 2 times (of course asking to ask for it) and after I received it, it started to sound like a whistling sound like the bolts that need to be lubricated from the right side. But when I first bought the car, I noticed that the handbrake was pulled up to the rear-view mirror (!). I wonder if I can associate this sound with him. Where does the hand brake apply when it is applied; Could this sound come because of too much pressure on that part?
08.05.2020 16:54 # 2
Probably the handbrake did not fully release. After a while that voice should pass. Does the sound still continue?
08.05.2020 16:54 # 3
FeverDog
Yes, it was a while later. I do not pull too much, thinking that it is from the parking brake, too. When I said that he did not fully release the handbrake, I had forgotten to lower the handbrake once.
08.05.2020 16:54 # 4
Cetinler
when the handbrake is applied, it can hold the two wheels on the back on the occasion of the pads. I hear your voice sometimes, sometimes there is no,
but there is another harm to apply too much power to the hand brake. he pulls the piece holding the two separate ropes, and because of the unnecessary force applied to me, one of the two legs of this piece was bent & nbsp; the right wheel is holding the rope tight because it is more tense, but the left wheel is not.
actually that piece should have been made of more solid material, but they did not do so ...
08.05.2020 16:54 # 5
tazmaniac
there is a nut on the hand brake for tension adjustment of the wire, you can partially adjust the number of teeth from there, but it requires fine adjustment ... so I don't think they will want a lot of money if you show a brakeer if there is an abnormality.
