tirptronik cik help
08.05.2020 15:12 # 1
Hi
when my 2003 model 307 automatically shifts the gear from P to R, there is a sound that comes out from under the vehicle (i.e. only the sound coming from outside when the window is open). (note: this sound is not heard from inside the vehicle)
08.05.2020 15:12 # 2
metin
It's very hard to hear from the gearbox right now because the gearbox is on the left front of the vehicle. The sound of the gears may be from the gearbox oil.
08.05.2020 15:12 # 3
BAHTIYAR
You say the electric voice, brother, probably a sound like zıztttt.
08.05.2020 15:12 # 4
no baho brother, a single exit like a bird click, like a metal piece, rubbing into another metal
08.05.2020 15:12 # 5
BAHTIYAR
I have not met before, brother Osman, I hope it is not important.
08.05.2020 15:12 # 6
Well, it's been a year since I bought the car. Until now, there was no problem, but I still wonder what could happen.
08.05.2020 15:12 # 7
current help
08.05.2020 15:12 # 8
I'm waiting for the help of current friends
08.05.2020 15:12 # 9
Serhun
Tiptronic (I do not know PUG completely) may be the system that comes from the pad. I guess that's because you say metal sound and does it when the brake is not applied.
It also makes such a sound when the vehicle is stopped, and when you test the vehicle, you encounter the same sound when the vehicle moves and loads the gearbox and the gear changes when you test the vehicle.
08.05.2020 15:12 # 10
BAHTIYAR
There is no system with dry clutch. There is a system with hydraulic torque convector. In 307, you said that the Ottoman brother now comes down when the brake of the downhill is released.
08.05.2020 15:12 # 11
naksi
that sound from the springs in the exhaust manifold
08.05.2020 15:12 # 12
sistemci
I think I have the same problem. When the car is getting ready for the attack in gearshifts, whenever I lift my foot off the clutch, there is a sound like metal friction (squisher.) Very disgusting sound.
Help from scholars;)
08.05.2020 15:12 # 13
[QUOTE = naksi] from the springs in the exhaust manifold that sound [/ QUOTE]
The correct manifold that my naksi friend said was coming from the bow there, I talked to the service the other day, even if you change that bow, it will repeat after a short while.
