tire split |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 17:48 | # 1 |
| 08.05.2020 17:48 | # 2 |
nexen is also good, actually it does not split and do not do my blood in the s2000 it is so wrong, it does not burn anything, it does not happen in the thin cheek maybe it may be if you enter the sukur fast but i think it is not dead How long did one get the tires
| 08.05.2020 17:48 | # 3 |
I think the 4-year nexen 6000 model was on when I bought the car. |
| 08.05.2020 17:48 | # 4 |
fexzi |
If it's 4 years old, it's fine.
| 08.05.2020 17:48 | # 5 |
The shelf life of the tires has already been left for 4-5 years, if you bought the car 4 years ago, if the owner has used these tires, you will find the age of your tire. If the tire split is rubbed against a hard object, you may have passed.
| 08.05.2020 17:48 | # 6 |
If it is 4 years old, it is normal, not rim or size, my friend, the splitting becomes this over time
| 08.05.2020 17:48 | # 7 |
205/40 17 which brand tire should I buy? or if I drop 15 inches, what do you think the size will be ![]() do you think this will happen with michelin tire 1200 TL or another 15 inch rim waiting for your comments |
| 08.05.2020 17:48 | # 8 |
fexzi |
If you want to avoid cash, I prefer the continental sport or premium contact series. After 45 cheeks, there is cheek protection. Places near the rim are harder and longer lasting.
| 08.05.2020 17:48 | # 9 |
p zero 275 tl michelin 315 biristn gave 315 price nexen yokohoma 200 tl they call conti 380tl |
| 08.05.2020 17:48 | # 10 |
fexzi |
continents have a campaign, research it, I bought an 18 inch set of tires, rear 255 front, 225 1400 TL.
| 08.05.2020 17:48 | # 11 |
impact |
We also talked in the meeting, I think the tire life was full, and if you entered hard, the pit was cut rim .. I agree with friends about repairs, it causes trouble for cheeks
| 08.05.2020 17:48 | # 12 |
Aziz |
May Allah give blessings, but if I was in your place, I would look at a petlas. I can not slide it for a long time. After the petlas, it is officially scanning the ground.
| 08.05.2020 17:48 | # 13 |
impact |
[QUOTE = Aziz] aghas Allah give blessings, but if I was in your place, I would look at a petlas. I can not slide it for a long time. After the petlas, it is officially scanning the ground. I say you like a lot of money, saint
| 08.05.2020 17:48 | # 14 |
Aziz |
[QUOTE = impact] [QUOTE = Aziz] aghas Allah give blessings, but if I was in your place, I would look at a petlas, I am using it, I'm glad, I did not run away from money, thank God, but why should I give more money to the same thing? I can not slide it for a long time. After the petlas, it is officially scanning the ground. I say you like a lot of money, saint [/ QUOTE] I do not say no, no, that means that you will give 300 odd to one tire and 2 of the tire doing the same job. I say pity I say good in Petlas: D
| 08.05.2020 17:48 | # 15 |
nexen n6000 same as my tire i'm glad i bought it last year As the friends say, the tire has expired .petles and nexen tires that can be used at affordable prices, I use summer nexen winter petlas. I have not had a problem.
| 08.05.2020 17:48 | # 16 |
goderyear the seller suggested nexen 6000 6000 8000 series has a reinforced cheek, so how about a 15 inch rim in the picture |
| 08.05.2020 17:48 | # 17 |
I know that xl (extra load) ones are reinforced cheeks. The place where I bought it was a try. I think the nexen i .15 inch rim is nice but it doesn't look as stylish as the rim on your vehicle.
| 08.05.2020 17:48 | # 18 |
[QUOTE = 307bursa] Don't think of falling to 15 or something and go get a nice set of tires. I personally do not have a brand obsession. In these works, I look at my budget. you go to the cheek-protected mielene and give 300-350 pounds, after that you enter the pit hard in a pensive moment, the room will be deceased, it puts you like child pain (it is fixed with experience) [/ QUOTE] so my teacher 205/40 17, put on a suitable tire, say late, don't do 15
| 08.05.2020 17:48 | # 19 |
impact |
I think 15 do not fit in your car. If you say I will replace it, let's trade with mine.
| 08.05.2020 17:48 | # 20 |
Mustafa-almanya |
It may be because the wipe is split from the cheek because the tire is old. If there are thin and thin fights in other places of the lastig, it is definitely old. You can check the age of the last one from the place where DOT is written. Some tire manufacturers have cheap brand tires. Their production can be outdated. If it says DOT 2211, this means that it was produced in the 22nd week of 2011.
