tire size
08.05.2020 19:36 # 1
onur3850
hello everyone
I have a 2012 model 112 hp e-hdi auto 6R 308 im.
the original canti 195 195 15 15.
I have no problems with handling, acceleration, braking etc. but the tires look very thin from the back. I am not satisfied.
Can I wear 215 60 15 tires on the same body?
What are the pros and cons if I can wear it?
When it goes from 195 to 215, does it rub the tire into the fender?
08.05.2020 19:36 # 2
mimit
I guess there is no alloy rim in your vehicle, passing from 195 to 215 does not have a negative impact on the diesel vehicle, but especially in the right and left turns, you have to check, you have to check, there are changes in the hoods according to the model years, the healthiest for it is to take control, 308s most of them come with 205 base sizes from the factory.
it would be better to create an opportunity and switch to one of the original wheel models with 16 rim size and 205 flat tires.
08.05.2020 19:36 # 3
darklebron
What you call 195 is the width of the tire. I think the tire rim with 215 base width will not be great. You may need to buy a wheel suitable for it.
08.05.2020 19:36 # 4
onur3850
There are alloy wheels on top, they said that you can wear a tire of 15 bases on each base.
08.05.2020 19:36 # 5
riderzist
You can use 205 65 15. I regret that I didn't take it that way. I have seen in fluence, you will not lose from comfort and handling increases.
08.05.2020 19:36 # 6
riderzist
If you wear 215 60 15, the vehicle will be lowered, the cheek will be thinner and will appear smaller. 205 65 15 seems like the most logical to me.
