Tire Sidewall Height
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 16:54 # 1
dmnbl
Hello,
My problem is this; I will buy a new tire as a result of splitting one of my tires; When I changed it, I said I would change at 4. I looked at the size of the tire that was slit in order to replace it and ordered it (205/50/16). But after seeing that 2 of the tires came today, I realized that the other 3 tires installed were 205/45/16, could the reason for the split be sidewall thickness? And if I get all the tires I bought, will there be any problems?
dmnbl 2012-07-16 21:56:14
08.05.2020 16:54 # 2
How does this work? Are they in different size, one in 3 different sizes? Didn't your vehicle pull? Well, I think the reason for the split is that the tire is replaced individually. It may have been used much more than others.
08.05.2020 16:54 # 3
hsnsnl
original tire size 205/55 16 "should be tire
08.05.2020 16:54 # 4
dmnbl
Nothing felt like right back wheel.
[QUOTE = koliva] How is this work? Are they in different size, one in 3 different sizes? Didn't your vehicle pull? Well, I think the reason for the split is that the tire is replaced individually. It may have been used more than others.
Got it. So is there any drawback of the height of the cheek if 4 of them are the same?
08.05.2020 16:54 # 5
[QUOTE = dmnbl]
Nothing felt right back wheel.
Got it. So, is there any drawback, if all 4 are the same cheek height?
How can not it be felt. The path of one wheel in one full rotation is 192.08 cm and the other one is 185.64 cm (45 cm). In other words, 50 wheels have officially dropped 45 leagues. This is why it was split.
Of course, 4 of them will have the same dimensions. It's not just a cheek. All. Even the speed values are ideal to be the same. How long have you been using this tool like this?
koliva 2012-07-16 22:42:42
08.05.2020 16:54 # 6
dmnbl
I have used about 5000km. So when I just bought the car. Then, let me get them on & nbsp; before the other 2 arrive.
08.05.2020 16:54 # 7
[QUOTE = dmnbl] I used about 5000km. So when I just bought the car. So let me get them on and do not set off before the other 2 arrive. [/ QUOTE]
What are the dimensions of the tires you bought? You can use it if it matches the other old two. Then you change these old ones, no problem.
08.05.2020 16:54 # 8
dmnbl
No, as I said, I bought 205/50/16 in its size because I was looking at the flat, so all the tires I bought now are 205/50/16. After replacing these, my 2 front tires will be 205/45/16, the rear will be 205/50/16.
So which ones do you suggest to be ahead of this time? Should I put the front back and new ones when it is installed, or should it be different?
The other 2 tires will come in 2-3 (the same) 07-16 22:53:35
08.05.2020 16:54 # 9
[QUOTE = dmnbl] No, as I said, I bought the size of 205/50/16 so I looked at the flat, so all the tires I bought now are 205/50/16. After replacing these, my 2 front tires will be 205/45/16, the rear will be 205/50/16.
So which ones do you suggest to be ahead of this time? Should I take the front and back of the new ones when installing them, or should they be different?
The other 2 tires will come in 2-3 (the same) ? Member
08.05.2020 16:54 # 10
dmnbl
I do not think so. I bought it on the internet and it would be quite painful to change it. Why do I have to change it?
What happens in trouble?
08.05.2020 16:54 # 11
[QUOTE = dmnbl] I think not. I bought it on the internet and it would be quite painful to change it. Why do I need to change it?
What is the problem?
Let's be an idea once, 4 will be the same size.
I asked for a change event because a friend of ours had the problem of kite when attaching the tire of the same size (205/50/16) to his GTI. If you want an arrow below. Now you come to order the other 3's in this size, then you can't wear it. I think that it is necessary to draw lessons from the experienced incident.
http://forum.peugeotturkey.com/forum_posts.asp?TID=22689&title=2055016-lastics-206-gt-ma-taklamad-yardm
I usually see GTIs 205/45/16 is attached. This is also what is written in the Servicebox. The decision is yours. koliva 2012-07-16 23:11:04
08.05.2020 16:54 # 12
dmnbl
[QUOTE = koliva] [QUOTE = dmnbl] I don't think so. I bought it on the internet and it would be quite painful to change it. Why do I need to change it?
I usually see GTIs 205/45/16 is attached. This is also what is written in the Servicebox. The decision is yours. [/ QUOTE]
Thank you very much for your interest. If not, I'll try to take care of it now.
Edit: Tried. 4 205/50/16 installed without any problems.
dmnbl 2012-07-31 01:23:42
08.05.2020 16:54 # 13
KenBlockJR
If the vehicle is 206, do not wear any measurements other than 195/45/16 or 205/45/16.
08.05.2020 16:54 # 14
MagicPerformance
If the dimensions of the fronts are the same with each other and the size of the backs are the same in itself, you should not have any problems.
08.05.2020 16:54 # 15
[QUOTE = umutrizaergen] If the size of the fronts are the same with each other, the size of the back is the same in itself, no problem, I use the back 225/40/17 in the rolls 185/50/14, it is very fluid :)
The problem is already there. 1 wheel different from the other end "Smile"
08.05.2020 16:54 # 16
MagicPerformance
So which ones do you suggest to be ahead of this time? Should I take the front and back when installing it, or should the new ones be important? Is it the other way? the same size is the same size for those in the back :)
Put the small turning circle in front of them.
